Door locked shut problem
Discussion in 'The Garage' started by woods, Mar 11, 2004.
  1. woods
    woods Registered Member
    Feb 18, 2003
    73
    so I was getting into my truck to head to work today, it had been raining/sleeting out all day. Door opened up fine and normal(it was locked)when I went to close the door the latch wasn't enaging, so I thought okay its froze so I slammed the door shut a few more times, latch still wouldnt close, so Im like crap I cant leave my driver side door open, so I get the bright idea to pull my door shut and then lock it, so I pull it shut and lock it, then I decide [darn] I should see if I can unlock it now, pull up on the lock and it wont unlock now, so now I gotta climb in through the passanger side.
    Any ideas on the problem??
    P.S 88 blazer full size 6.2 silverado with power locks
    thanks Woods
  2. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    You're going to have to get inside the door and look. Sounds like something came apart.
  3. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    sometimes those hook shaped things will drop down, if that is it you need to release the top part and set it back where it belongs..make any sence /forums/images/graemlins/confused.gif
  4. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    What Shawn said.
    The rotary latch needs to be pulled up manually.
    Rene
  5. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    if if will work for you, take a radiator clamp, take it apart and make a shim out of it, slide it down right next to the latch I hope I make sence /forums/images/graemlins/confused.gif
  6. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    An idea. I sometimes can't unlock my door from the outside. Press in on the button on the outside like you were going to open the door. Then try unlocking it. It works for me!
  7. B_to_C
    B_to_C 1/2 ton status Author
    Jan 15, 2003
    1,861
    In Government Housing
    Same here! Mine it started AFTER I locked my only /forums/images/graemlins/doah.gif set of keys in the truck and had AAA come out and jimmy /forums/images/graemlins/deal.gifthe door open.
  8. elacruze
    elacruze 1/2 ton status
    Dec 23, 2003
    121
    SE Michigan
    Rut-roh.
    It begins with the lock. It ends when the rusty latch mechanism won't return via the spring, and you can't open the door at all. Then, if you're lucky, you can spray some penetrant down the window and tap/vibrate it loose. Then you can remove the door panel and fix it right.
    If not, you'll have a 2"x4" hole in the door below the heyhole, like I do on both sides of my '85K15. /forums/images/graemlins/hack.gif
