door locks. semi urgent need them to lock tomorrow
Discussion in 'The Garage' started by blazeonchevy, Aug 20, 2006.
  1. blazeonchevy
    blazeonchevy 1/2 ton status
    Jan 13, 2006
    401
    san antonio tx
    this is frustrating... i put doorlocks in my truck that i have a key to. the drivers side works fine. the passenger side works fine with the door open.. but if i close the door, then lock it, it wont unlock to save my life.:mad: i have to get the door panel off and pull up really hard on the piece that the key moves up and down to unlock it. i dont understand why it wont unlock...earlier today i was messing with it and i just sprayed it w/ wd40 and it started working a little better. i left the door panel off closed the door and locked it... IT WORKED FINE! then i put the door panel back on closed it and locked it,, it wouldent unlock:mad: :doah:...... i finally got it unlocked in a fit of shear masculinity:haha: but im scared many more of these and things are going to break:rolleyes:..
    end smiley infested post..
    thanks. -sam-
  2. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
    is the panel stopping it from opening? i dont think theres a place for it but maybe? spray lube in hte lock and around the lock and the bar movement points, everywhere theres movement. i only have that ptoblem because faulty aftermarket auto locks so i just muscle it if it happens
  3. shepdog
    shepdog Registered Member
    Jul 16, 2006
    35
    TRACY,CALIFORNIA
    Take the doors off and your problem will be fixed. Just kidding. i know when I'm stressed it helps to laugh.
  4. savagek5diesel
    savagek5diesel 1/2 ton status
    Nov 20, 2003
    310
    Redding California
    my driver's door lock was jammed up pretty bad for a while, i ended up taking all the linkage apart, and found out it was jamming in 2 spots, one right off the lock, and the other @ the electric selenoid, works like a champ now.
  5. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,072
    484
    Grand Rapids area
    Don't know if this will help, but sometimes I can't open the door with the key unless I first push the button in and then turn the key.
  6. JpEater
    JpEater 1/2 ton status
    Nov 20, 2005
    299
    Augusta, Georgia
    mine does the same thing. Just try to push the button in before you try to unlock it. It works for me because I don't have time to find out whats up with mine.
