Door panel removal
Discussion in 'The Garage' started by Badger, Aug 28, 2005.
  1. Badger
    Badger Registered Member
    Aug 23, 2005
    11
    Wisconsin
    Hey there, I am trying to get the drivers side door panel off my wifes 90 Jimmy. The window is not working, I have removed all the screws and such, but it seems to be stuck on the top by the window. I can't see anything else that I need to remove, I was trying to remember years back when I had another vehicle that I removed the door panel on. I think the panel had a lip at the top that slid down, any help out there if this is the same? I just don't want to break anything as panel parts are not easily replaced. Anybody have a suggestion?
  2. ryoken
    Jun 13, 2003
    29,623
    1,379
    Jersey Shore
    if you can, put the window down.. makes the top clip easier..
    push the top of the door panel in towards the glass and lift up from the bottom...
  3. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Never done a later model one, but there are generally clips near the bottom...gently pry those loose first. Then the upper sill area is usually resting on a lip so by lifting up on the entire panel you can lift up and off.
    Sometimes there are screws hiding in the door pulls or armrests....double check for those too.
  4. Badger
    Aug 23, 2005
    11
    Wisconsin
    OK, thanks, I thought it might be something like that, I'll give it a try.
  5. Badger
    Aug 23, 2005
    11
    Wisconsin
    Hey thanks guys, it worked, now I just have to figure out what's up with the window. :bow:
