Door panel removal?
Discussion in '1992-Present Chevy & GMC models' started by Jonathan, Sep 7, 2002.
  1. Jonathan
    Jonathan 1/2 ton status
    Apr 14, 2001
    293
    Little Rock, Arkansas
    I need to get the passenger side door panel off to fix the inside handle cause it doesn't work. How do I do it? The window crank doesn't seem to have the little clip like my K5. How do I get that off? What else do I need to get off to get the panel off? Thanks
  2. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    It has a spring clamp behind it that needs a crank removal tool. Pretty simple with the tool. For the door, just take the 2 screws in the arm rest part out, pull the trim around the handle off, and pop out the little switch panel. Also the little triangular panel off the bottom of the a-pillar. Once those are off you can work from the bottom up popping off the panel. Use a panel removal tool for this or you will break all the clips. Thats pretty much it.
  3. Jonathan
    Apr 14, 2001
    293
    I bought a crank removal tool yesterday but I don't see a clip like on my Blazer. Does it come off the same way? I don't want to open the tool until I'm sure it will work.
