Door Panel Removal
Discussion in 'The Garage' started by RustBuket, Feb 19, 2004.
  1. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    I'm in the process of trying to remove my door panel from the inside but I can't seem to remove it. I need to be able to take the window crank off. How do you do this? Is there something else I may be missing? It's really starting to anger me. /forums/images/graemlins/1zhelp.gif
  2. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    The window crank is held on with a little C-clip that needs to be removed in order to pull the handle off. If you push the door panel in you can peek behind the crank and see it.
    You can buy a tool that is made specifically for these stupid little C-clips:
    I've always used a screwdriver. /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif
  3. RustBuket
    Feb 21, 2003
    1,618
    Wow, that helps alot! Thanks man! /forums/images/graemlins/thumb.gif
  4. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    Use a thin screw driver..that special tool WILL sit in at the bottom of your tool box. /forums/images/graemlins/waytogo.gif
  5. GM Man
    GM Man 1/2 ton status
    Jan 12, 2003
    549
    Denver CO
    After you remove the window crank, you'll have these clips that are at the top of the panel, where it meets the glass, and they dont like to come off. On mine I had to tap up on the panel until it came free. I thought I was going to break it but I didnt. Good luck with yours.
