Door panels.......one more time
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 84CUCV, Feb 15, 2004.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    Just took mine off and broke the plastic. Tried to take out window switch and broke that too. What the heck am i missing? are there tools for this?? What is the blue thing on the back of the window switch and why in the hell cant i get it off!! I feel likr it is going to break if i pull/pry any harder. All i need to do is replace the thing. I thought it was just pressed on. Thanks mike
  2. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    on the back of the electric switch? Easiest way is to take the switch out of the door panel, and then stick a flat blade screwdriver between the switch and the blue plastic piece and pry it up off. If you touch the posts your windows may try to go up and down, so may want to disc the batt. Isnt too hard, when i took mine off one was real easy, other had sort of corroded on, took a bit of prying. Just be careful not to pull the wires out of the side of the connector. /forums/images/graemlins/whistling.gif
  3. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    yea the back of the switch. thanks mike
