Door panels wont come off???
Discussion in 'The Garage' started by Capnscoop, Apr 5, 2007.
  1. Capnscoop
    Capnscoop Registered Member
    Mar 25, 2007
    43
    South Florida
    My Door panels wont come off...any tricks????
  2. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Are you sure all the screws have been removed?
    THere's a line of screws on the bottom and 2 screws in the armrest, then the only thing holding it is the plastic ribbed pop-in pieces, so you just pull and it pops out. You usally have to pull on the bottom edge, get it all loose, then lift it straight up off the window edge, the inner window weather strip is attached to the door panel.
  3. dyeager535
    26,982
    191
    There is also one screw that ISN'T along the bottom nor the armrest. I believe it's towards the rear of the panel, behind the armrest.
  4. bluehen
    bluehen 1/2 ton status
    Nov 11, 2004
    215
    DE
    There's behind the handle too.
  5. fireplug
    fireplug 1/2 ton status
    May 3, 2005
    1,692
    Toronto, Canada
    Been a while, but I think my '89 had one behind the inner door handle? Or maybe that's one of my other rides...either way sometimes even with all the screws out, it requires a surprising amount of upwards force to breakem' loose.
  6. Capnscoop
    Mar 25, 2007
    43
    South Florida
    thanks i got em off....now how do i pull the side mirrors???is it that single allen bolt??
  7. dyeager535
    26,982
    191
    Allan bolt holds the cover on, you slide that up the mirror arm, then unbolt. 10MM socket I believe.
