door panels
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dpearson, Jun 19, 2000.
  1. dpearson
    dpearson Registered Member
    Apr 10, 2000
    95
    El Paso, TX
    Has anyone painted their door panels and is there anything that will really adhere???
  2. BlazerBoy
    BlazerBoy 1/2 ton status
    639
    Chicago IL.
    I painted all of the plastic trim (pillars etc.. ) With reqular spray paint and it looks great, hasnt come off or anything.. It should work on your door panels good luck..
    BlazerBoy
    http://generalblueballs.coloradok5.com
  3. dpearson
    Apr 10, 2000
    95
    El Paso, TX
    I painted them with "plastic" spray paint and after a year or so they started flaking, I was hoping someone has used something like por-15 or equivalent to completely dunk them in.
  4. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
  5. 4x4blazer
    4x4blazer 1/2 ton status
    Jun 14, 2000
    278
    Louisiana
    I paintedmine with Flexstone, that gave it a textured finish and it hasn't flaked at all. That was about 6 years ago.
  6. jmpd
    jmpd 1/2 ton status
    Mar 12, 2000
    181
    Mesa, AZ
    I haven't done the door panels, but I have done all of the other plastic around the cab to match the grey tweed. I used interior paint. It works pretty well, But I'm not sure how it would work on areas that get touched or used a lot
  7. Blazerbob
    Blazerbob 1/2 ton status
    214
    Western NY
    I painted my dash and door panels with interior paint from Autozone and it has held up fine.
    <font color=blue>Blazerbob</font color=blue>[​IMG]
  8. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    I agree with BlazerGuy. I think dye would be the best for door panels. Ask a car stereo shop in your area about what type of dye would be best because most of those shops carry the Q-logic kickpanels that are made to be dyed. Door panels are made out of the same material.
    '73 K5
    Chevy good...Ford bad
  9. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    Interior paint or dye as it is also called should work fine.Have bought it at auto zone and pepboys. The most important thing is surface prep,must be very clean. There is also a product out to spray on plastic parts to make it stick better. You can get all of this stuff at eastwood.com. They sell restoration supplies and tools.
  10. coopertwpk
    coopertwpk 1/2 ton status
    Mar 18, 2000
    478
    Spring Valley Lake Ca.
    You can have automotive paint shops mix it for you it is a special paint for plastics and they color match from the original codes.
  11. dpearson
    Apr 10, 2000
    95
    El Paso, TX
    That sounds like the best approach, I suppose it is similar to the paint on the plastic bumpers. Thanks for the suggestions!!
  12. Can I get a redo on that link? As much as I would like to visit the Tourist house that is at that link, I would still like to see some restoration supplies. Just playing. Thanks though.
