Door pins and bushings...
Discussion in 'The Garage' started by kp texan, Jun 14, 2005.
  1. kp texan
    kp texan 1/2 ton status
    Sep 8, 2003
    211
    Corpus Christi, TX
    I just purchased some new GM door pins and bushings from the dealer for my '88 K5 and I'm in the process of trying to cut through the old pins in order to remove them. I know some of you guys said that you cut through these pins without unbolting the hinges. What did you use to do this? I'm trying to use one of those little hacksaws where just the blade sticks out of the end and I'm almost getting nowhere on the bottom pin :mad: . It seems like there isn't nearly enough room to cut these without unbolting the door from the hinges. Any help would be appreciated!! Thanks so much, guys. :thumb:
    -Wes
  2. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Sawzall.
  3. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Just use a hammer and tap them out from the bottom. They arnt hard to get out.
  4. eclipse
    eclipse 1/2 ton status
    Jan 1, 2005
    1,245
    Sparks, NV
    I've unbolted doors on my 77 and I spray painted white where they bolted to the door as a guide to line them back up when I put them on. And then I got another set of doors and you could see the color difference on them where to line them up, made it easier to rebuilt them to the hinges. Seems like it would be easier to me to replace the pins with out the doors hanging.
