DOOR POST?>
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazing86, Mar 4, 2001.
  1. blazing86
    blazing86 1/2 ton status
    Dec 24, 2000
    290
    Ok my driver side doors seems to drop down alittle bit when i open, but it goes back into place when i close it. Im wondering if this couild be the door post? If so, how much work is involved in this?
    thanks
  2. dewey
    dewey Registered Member
    Dec 17, 2000
    59
    MA
    Sometimes the pins get loose on the hinges...Check to see if the holes are worn, open the door and have someone lift up and down while you look...If so, replace the hinges...My .02
    HEY! Your ford scratched my skidplate!!
  3. BMR
    BMR 1/2 ton status
    Feb 25, 2001
    132
    Northern Colorado
    Try putting a shim in the bottom hinge to kick it up. It worked for my friends 87.
  4. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    It sounds like the bushings on your hinge pins are no good. You need to remove the door from the hinges. Take a sharpe marker and outline your hinge, then remove the bolts. Have a friend help you as the door is pretty heavy. Then remove the pin from the hinge. I think the bushings will stay in the hinge. You need to knock them out. You can buy new bushing from any parts house for a few bucks. Replace the doors and your all set. Piece of cake, ask anyone here!!!!
    creepin' and crawlin'
    Jim
  5. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
  6. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Also check for a cracked upper hinge.
    <A target="_blank" HREF=http://jamonline.homestead.com/fromthegroundupK54x4/89Jimmy.html>http://jamonline.homestead.com/fromthegroundupK54x4/89Jimmy.html</A>
    <font color=blue>Happy Trails[​IMG]</font color=blue>
    <font color=blue>Wayne</font color=blue>
