Door Removal Options, What have you done.
Discussion in 'The Garage' started by k5freak44, Jun 13, 2005.
  1. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    Heres my problem. Im looking to do the door pins article to my blazer but i have one problem...................
    13 wires on the passenger side and too many to count on the drivers side.
    Should i just give up now or is there anything i can do to make this possible.
    Or Should i just get 30+ male/ feamale connnectors???
  2. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    there is a connector up under the dash for both the pass and drivers side that you can disconnect and pull whats left out through the hole in the door frame. Personally, in spite of these "quick" connectors, I found that to be such a PITA that once I disconnected them I left them disconnected until I finally sold my doors.
    j
  3. B_to_C
    B_to_C 1/2 ton status Author
    Jan 15, 2003
    1,861
    In Government Housing
  4. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Go to the junkyard and cut out the connectors (plus like a foot of wire) from a truck with the same stuff you've got. You can then make pigtails. You can then pull the factory door harness out and into the door. Then when you want to run doorless you just have the one connector and you can stuff it back in the A-pillar. Since you'll be running without a boot this way you don't have to worry about your factory wires getting hurt.
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yeah you could get insulated spade connectors for this
    i need some urls to door pin conversion threads on here
    how do you guys do it ?
    what pins do you go get and where ?
    what diameter are they ? length ?
    bushings ?
    pics ?
    want to do this to my 81
    anyone ?
    thanks
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Very slow and methodic . I used the bullet connectors with built in heatshrink . Crimped on each wire , heatshrinked down as a strain releif . I could swear since I did the wires that mt pass window got slower from the drivers side switch , since its faster with its own doors switch . ( I ain't done the pins yet , I just sharpie marker around hinges and unbolt ;) ) .
  7. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    what are all those wires for? Just for power windows and locks, speakers?
    I have 1 wire per door :grin:
  8. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    You should use a multipin connector like the factory uses for size, ease of use, and cost. It'd be real easy to take some factory ones, solder the two ends together, and have yourself an extension piece.
  9. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    He has power locks, windows, speaker, and the power mirrors. :blush:
    I thought my 8 wires per door was bad :D
  10. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    so i have factory connecters in there now, and you are saying to find some more at a junkyard and just solder the new one in.
  11. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Right. You find another set of factory connectors from another vehicle. You cut them with about 8-12" of wire on each side. You then solder these ends so it's a "passthrough" harness. This allows you to "move" the connection to the door area instead of up under the dash. This way you don't have to string wires up under the dash or have 25612435 different spade connectors.
    It doesn't get much easier than that. It'll take you a while to find a vehicle with the connectors and it'll take some soldering. However, when it comes time to pull the doors off it'll be cake.
  12. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    i dont know how easy it is going to be finding, a k5 blazer with power mirrors but ill try
    ima also check some newer models
