door removal with power locks and windows
Discussion in 'The Garage' started by eshorvath, Jan 30, 2006.
  1. eshorvath
    eshorvath 1/2 ton status
    Jun 20, 2002
    373
    Southern Oregon
    Has anyone remved the doors from a K5 with power locks and windows?
    Any quick connects installed to make re-installaton easier?
    Pictures? Ideas?
    Eddie
  2. ftcjimmy
    ftcjimmy Registered Member
    Mar 9, 2005
    61
    ct
    WHat i did was break the rivits, take outt that rubber waire wrap thing, then took off the iner door panel. after that i disconected the plugs from the window motor and the lock cylinders. then you have to disconnect them from where there connected to the inside of the door and feed them out through the hole. Next if the replacement isnt powered, then you have to transfer everything dfrom door to door. The with the new door on reconnect all of the plugs. keep the wiores following an original path so you dont get nething caught up in the window motor.
