Door removal
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by i_4x4, Mar 1, 2002.
  1. i_4x4
    i_4x4 1/2 ton status
    Feb 20, 2000
    359
    Brighton, Colorado. USA
    I have power doors. I want to know if there is quick connecters on the wiring harness behind the kick panel. So i can remove the doors w/o cutting the harness. Any info is appreciated.
    Later Ed
    I'm not tail gating. I'm DRAFTING.
  2. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    I dont think there is, I believe you have to unhook the wires at the power lock and power window motors.
    <a target="_blank" href=http://www.geocities.com/outlaw613/K5.html>http://www.geocities.com/outlaw613/K5.html</a>
  3. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    Hey Ed long time no see
    But I think Outlaw612 is right you will have to take the wires off at door and window thing
    Eric
    &lt;a target="_blank" href=http://cethern.tripod.com/erics-home-page-and-other-stuff/&gt;http://cethern.tripod.com/erics-home-page-and-other-stuff/&lt;/a&gt;
    AMSOIL Dealer # 529948
    &lt;a href="mailto:Cethern@interfold.com"&gt;Cethern@interfold.com&lt;/a&gt;<P ID="edit"><FONT class="small">Edited by Highlander on 03/02/02 08:18 AM.</FONT></P>
  4. 85m1009
    85m1009 1/2 ton status
    Jul 11, 2000
    718
    Missouri
    There is a connector behind the kick panels. You have to remove the plastic end from the door side so the wires will slide out. If you are wanting to make them removable you can wire in door pin connectors, similar to what is on the rear doors of a newer Suburban. Only catch is that nothing will work unless the door is closed.
    <font color=green>Steve Frisbie</font color=green>
    <a target="_blank" href=http://www.mo-offroad.com>www.mo-offroad.com</a>
  5. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Damn, theres a connector? I cut some of the wires when I did my door hinges...
    90K5
  6. 87GMC
    87GMC 1/2 ton status
    Nov 5, 2001
    653
    Olathe, KS 66061
    You could go to the Chevy dealership and get a weathertight connector for the doors. Just tell them how many wires you need in the connector. I might be able to find a part number if you have trouble.
    87 V1500 305 TBI 208/465 4" 35"procomp mt Dana 44/12 bolt
  7. i_4x4
    Feb 20, 2000
    359
    Thanks guys for the ideas. My only concern w/ the weather tight connecter, or the door pin style is will they be able to handle the amps ofthe power window? I want to make them removeable for Moab. Since everyone seams to be sheading pounds for this. As I have never ran w/o doors. I just want to keep it simple stupid.
    Thanks again for you replies. ED
  8. 87GMC
    Nov 5, 2001
    653
    Olathe, KS 66061
    Should be no problem, GM uses the wheathertight connectors on almost everyhting under the hood, including the alternator and the main engine harness.
