Door sagging.
Discussion in '1983-2005 S-Series models' started by 85 Shortbox, Apr 4, 2002.
  1. 85 Shortbox
    85 Shortbox 1/2 ton status
    Jan 24, 2002
    138
    Grandville, Mi
    I have a 91 S-10 ext. cab and the drivers' door is sagging causing an annoying air leak, so how do I fix it?
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    The first thing to do is to replace the bushings and the pin for the door hinges and see if that works. You can get them in the "Help" section of most parts stores. There isn't any adjustment that you can do unless you want to cut the welds!
  3. 85 Shortbox
    Jan 24, 2002
    138
    Grandville, Mi
    That is where all the slop is, but what I can't figure out is how to remove the pins.
  4. Viper31
    Viper31 1/2 ton status
    Nov 3, 2000
    108
    Washington State
    i use a little block of wood under the jame then closed it to take the sage out of mine
