Door Speakers
Discussion in 'Audio' started by Big Red, Jul 16, 2003.
  1. Big Red
    Big Red 1/2 ton status
    Jan 9, 2003
    250
    Bristol, CT
    Ok, heres the deal, i bought Alppine SPS_170A's a little while agoi (the 6-1/2 2-ways) I wanna put them in the dorrs of my 87 blazer, but i have both power locks and windows. this is a problem as i can't see a way to safely cut a hole and mount the speakers so the magnets dun magnatize the whole door, scrape/rub, etc. on the moving parts. Any help would be very greatly appreciated as no stereo system sucks. thanks guys. /forums/images/graemlins/thumb.gif
  2. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Keep the speakers in the lower front part of the door below the vent window. That's typically the most "open" spot because the glass above it doesn't roll down.
    Then pull out the map pocket (or pull the door panel) and take a few measurements for mounting depth in that area. You want to determine how far "in" you can go before you hit anything inside the door....once you have that "magic" number, compare it to the mounting depth of the speaker you want to install.
    The difference between the two numbers (if there is a difference) will be the size of the spacer ring you'll need to build to put between the speaker frame and the door.
    That's the simplest way.
    Or you can figure out how to modify the door to relocate whatever is in the way of the magnet, and then mount the speaker flush.
    Definitely use a little "dynamat" type stuff on the outer doorskin and inner door while you have everything apart. It will help to seal up the area and stop any rattles before they start.
  3. Blazn88
    Blazn88 Registered Member
    Dec 11, 2002
    83
    Northern California
    You can do as Greg72 suggested or you can do like I did and build a speaker pod that mounts to your door and put the speakers in them..PM me and I'll send you some pics. /forums/images/graemlins/k5.gif
  4. DOCKAWI650
    DOCKAWI650 Registered Member
    Sep 29, 2002
    61
    Gboro, NC
    i have 6 1/2 speakers mounted right behind the drivers seat past the door and they sound great.
