Door strike question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bajaviking, Mar 6, 2003.
  1. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    I want to take of the door strike to replace the plastic roller bushing( no idea what it's really called) that helps the door lock close. If I take of the door strike will the nut on the back fall down? Do I need to get to it from the inside?
  2. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    Yes! It's not really a nut, it's a threaded piece of steel about 2" square.
    Yup. But it's pretty easy. Just remove the trim piece and you should be able to get at it.
  3. BlazerWheels
    BlazerWheels 1/2 ton status
    Feb 13, 2003
    587
    California
    I replaced both of the door strikes on my '85...simply unscrewed the ones that were on it and put on the new ones. /forums/images/graemlins/cool.gif Nothing fell down, didn't have to take off any trim, no problems. /forums/images/graemlins/grin.gif Got my doorstrikes at Pep Boys. I had to buy a torx 50 for them though.
  4. lt61173
    lt61173 1/2 ton status
    Apr 9, 2002
    105
    Republic, Pa
    The square nuts are built into a box like the nuts for the cap so they should not fall unless the box is broke like mine.
  5. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Here's a cheap alternative to replacing the plastic piece on the door striker:
    Take a roll of electrical tape and give the striker about 5-7 wraps of tape where the plastic piece normally sits. The doors on my 84 never seemed to close properly in the last few years. The tape trick solved my problem.
    The bonus is when the latch mechanism wears the tape down too much, you remove the old tape and throw a few fresh wraps on.
    Gotta love cheap fixes!!!! /forums/images/graemlins/thumb.gif
  6. bajaviking
    Apr 10, 2002
    752
    Baja
    I tried that but after a couple of years I am kind of tired of putting tape on every 3 months. Besides the plastic rollers whatevertheyarecalled are only a couple of dollars.
  7. JROSS
    JROSS 1/2 ton status
    Oct 12, 2001
    281
    Redding, CA
    i GOT MINE FOR $.67ea. Best $1.34 ever spent. /forums/images/graemlins/thumb.gif
  8. MILOLGJC
    MILOLGJC Registered Member
    Sep 27, 2002
    29
    FL
    Where did u find the plastic roller. I can only find Ford rollers at Napa, PEP boys etc. Bought that one and rotored out the interior size to fit.. Short term solution though.
  9. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    The plastic piece you are talking about is called a silencer. I have replaced them on ever truck I've had. I bought mine at the local Chevy dealer for about 50-60 cents each. Before you remove the stiker bolt, I would suggest making a mark on the door jam where it's at now so you can line it back up exactly where it was when you go to reinstall the striker bolt.
  10. bajaviking
    Apr 10, 2002
    752
    Baja
    Just fixed mine this week-end, a couple of dollars and 30 minutes of work. The doors close real nice and tight now.
    By the way, to answer my own question the door strike did not fall down on the back. /forums/images/graemlins/thumb.gif
