Door Striker Bolts
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 2Dogs, Apr 28, 2003.
  1. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    All,
    My Dealer quoted me $32/side for these - WTF? Is that the best deal? I doubt it.....
    What are some alternatives? If you have used aftermarket what brands are good quality?
    Thanks,
  2. Hardcore
    Hardcore 1/2 ton status
    Apr 25, 2003
    458
    New Orleans, LA
    I bought some for my old Ford from JC Whitney. I think it was $12 for a pair. They seemed to be quality parts
    Corey
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Check out the section with the "Help!" brand stuff at your local parts store. /forums/images/graemlins/cool.gif
  4. dyeager535
    26,982
    191
    Go get used ones.
  5. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    i got the ones from LMC dont remember price but seems like it was under 10 for some reason.
  6. wadinator
    wadinator 1/2 ton status
    Dec 18, 2001
    233
    NW Iowa
    How do you change them anyways? I always thought that there must be a nut on the inside of the metal panel that would fall into "never never land" if you turned the striker all the way out. /forums/images/graemlins/ears.gif
  7. greybeard
    greybeard Registered Member
    Sep 29, 2000
    43
    Dallas, Texas
    I used the ones from the "help" section at the auto parts store. They seem to work fine!
  8. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Its a captured nut that is welded in place. It wont go anywhere.
  9. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    Cheap and easy to get at NAPA or Pepgirls. Mostly in the Help section. They will be labelled for GM trucks. To remove the old ones, stick a Torx head socket in there, unscrew it and screw the new one in. Easy. Unless it's like my truck and the weld in nut is toast...
  10. wadinator
    Dec 18, 2001
    233
    NW Iowa
    Hmm, I see.
    Learn something new every day! /forums/images/graemlins/thumb.gif
    But if I go to change them, and that nut falls, I'm gonna /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif just kidding dude! I check er out on my old rust bucket body that melting away in the grove first though.
  11. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    I need to change the drivers side but the Torx head is shot. How do I remove it now ? Can I use a pair of pliers any ideas.
    Dan..
  12. wadinator
    Dec 18, 2001
    233
    NW Iowa
    Vice grips maybe /forums/images/graemlins/confused.gif /forums/images/graemlins/thumb.gif
  13. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    Dan..
    Vise grips, pipe wrench or a great big pair of Channel-locks
  14. Skigirl
    Apr 2, 2001
    2,563
    Definitely vice grips. If it doesn't unscrew easily shoot some PB blaster or something similar in there.
  15. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    And if those don't work grind two flat spots on it so you can get a wrench on it. OR weld a dang nut on the end and start turning- maybe use a lil PB Blaster if it acts stubborn.
