Door Swaps
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 77blazin, Sep 15, 2001.
  1. 77blazin
    77blazin 1 of a kine K5
    Mar 31, 2000
    394
    Honolulu Hawaii
    Can you use a 1973 Fullsize Pickup doors on a 1977 K/5 Blazer?
    I heard from the grapevine that you can, But others are saying you can't?
    Any imformation would help?
    Michael
    1977 K5 Blazer
    1975 K5 Blazer
    Running over those big waves that rocks us
  2. NorthernRedNeck
    NorthernRedNeck Registered Member
    Apr 19, 2001
    36
    Ontario, Canda
    Sure they should bolt up just fine as long as you don't have a full hard-top, all the doors are the same from 73-87, for pickups, and right up to 91 on the Jimmy/Blazer, the only differences are the mirrors, door panels and power options
    '89 Jimmy SLE 350/700, sadly 2 close to stock, much lighter thanx to salted winter roads!
  3. bigjbear
    Feb 18, 2000
    13,966
    448
    Marietta GA
    The skins are the same, but the guts & int are differant. If you're doing a resto they are not an exact match. If you want a good functional replacement they are a bolt on swap.
    Jim '80 GMC & '73 Blazer
    Tread Lightly!
    <a target="_blank" href=http://www.tellicok5.rockcrawler.com>www.tellicok5.rockcrawler.com</a>
  4. chevrules
    chevrules 1/2 ton status
    Aug 26, 2001
    127
    Canada
    Those doors will work fine
    chevrules...always has and always will
