Door torque spring/rod? Anyone replace
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fireinthehole, Jul 30, 2003.
    Just got this Sub last Sunday and the passenger door wont stay open. Couldnt figure it out, so I started comparing it with the drivers door and found that the torque rod (what the parts guy called it) was broke. Its shaped like an "S" I think. Anyway, has anyone ever replaced it? I ordered one, but was wondering how to fix it. Any ideas?
    Mat
  1. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Mat
    I haven't done it, but I know they sell a special tool to use when replacing it. Must be a PITA with standard tools. /forums/images/graemlins/grin.gif LMC sells the tool if you can't find it locally.
  2. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    Hey,
    I had one break on me...Just get one from a junkyard. The only tools nessacery to install it were a hammer and a small crowbar. Place in into position....with one end of the "s" in it's spot. Then use the crowbar to push the spring loaded part in and hit it wil a hammer into position.
    2 minutes tops...
    Blake
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    What he said, i've had to do the same thing, and used the same method, works excellent /forums/images/graemlins/thumb.gif
  4. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    its one of those bottom of "toolbox" discounts at the pick a part...if you know what i mean /forums/images/graemlins/cool.gif
  5. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    It's such a cheap part, why buy it from a junk yard? Anyways, it's a 2 minute job w/ hand tools, if you can change a spark plug, you'll be fine /forums/images/graemlins/thumb.gif
