Door window vents.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by santana, Jul 4, 2003.
  1. santana
    santana 1/2 ton status
    Jan 11, 2003
    1,483
    Mesa Arizona
    I'm trying to remove the vent window locks but can't figure out how. Has anyone got any idea on how to do this? /forums/images/graemlins/confused.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gif
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    if memory serves me correctly, there is a roll pin on the bottom side of the lever, you need to push that out in order to take the lever off first /forums/images/graemlins/thumb.gif
  3. santana
    Jan 11, 2003
    1,483
    Mesa Arizona
    I see, I'll try that, Thanks!!
  4. dyeager535
    26,975
    Believe the roll pins go out/in only one way, so don't bust your vent window trying to remove it. /forums/images/graemlins/smile.gif
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yes roll pin you have to press it out with a small diameter nail or similar, be careful, then when you get the pin out the handle come soff and rest is straight forward easy, if the pin wont fit tight enough to stay put when you reassemble handle assembly then make a flat spot in the pin just enough to make good interference press fit in the hole in the handle so it wont go anywhere, make flat spot towards one end of the pin
    there is a spring under the lock button be careful and dont let it run away from you whe you take handle off, sometimes the button and spring fly off/out but not always
