Door won't unlock.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1990SilveradoK5, Apr 18, 2001.
  1. 1990SilveradoK5
    1990SilveradoK5 1/2 ton status
    Jan 2, 2001
    185
    Napoleon, OH
    Door won\'t unlock.
    OK it has happened twice now. Go to open the passenger door and the mechanism will not unlock. Electrics try, even pulling up on the now broaken manual plastic thingy will not work.
    Is it just gummed up or am I lookin at replacing parts.
    Yes it was me that posted a day or two ago about my tailgate not opening. Soon I will have to leave the windows down so I can climb in. ALLA Dukes of Hazard style.
    Gone Large and Loving It.
    Keith
  2. dyeager535
    26,982
    191
    Re: Door won\'t unlock.
    If you can't pull up on it, it's the mechanism. You can try spraying the door latch mechanism, and everything behind it, wih WD-40 to se if it helps. "Course WD-40 isn't the recommended lube because it will attract dirt, but if it works, it works.
    If you can't fix it that way, then pull the door panel and attack from the inside. The lock solenoids are very weak, and aren't strong enough to prevent you from opening the lock, unless of course they are broken, which I have seen...they wouldn't open or close.
    Dorian
  3. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    Mine did that for ever. Do yours still not unlock even pulling up by hand
    (pull thing just wont move)? If you just dont care about them working right mine were cured by moving the outside latch then unlocking the door. I lubed mine abck up with lithium grease and they work fine.
    "There is a fine line between hobby and mental illness"
    Luke
    84 K5 [​IMG]
  4. Itali83
    Itali83 1/2 ton status
    Feb 12, 2001
    795
    Westbrook Maine
    Mine does this on the pass door every once in a while, Puch the black button on the outside handle as if you were going to open the door, that does it every time. then procede to unlock your door. Good luck.
    Ben 87 Jimmy
    <A target="_blank" HREF=http://www.bens87toy.coloradok5.com>http://www.bens87toy.coloradok5.com</A>
  5. Truckfan2
    Truckfan2 1/2 ton status
    Apr 10, 2000
    343
    Northern IL
    My '89 Jimmy does that with power locks too. My dad said it was because the outside door handle was worn out and needed to be replaced... he's seen alot of that problem at the Chevy dealer he works for.
    Have been stuck (once) as of 8/12/00
  6. blazentank
    blazentank 1/2 ton status
    Apr 18, 2001
    426
    Houston, Texas
    my brothers did that a couple of times he thought i broe it but never toughed the damn thing i just pulled and pushe buttons for 5 minuted and kazam it just opened
  7. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    <blockquote><font size=1>In reply to:</font><hr>
    Ben 87 Jimmy
    <hr></blockquote>
    Have you tried that yet? Thats the same way on both of my doors and I have to push the button before I turn the key or it wont unlock!!! Give this a shot. I'm 99percent sure this will fix it.
    Michael
    <font color=blue>Professional <font color=red>JEEP EATER</font color=red> it's a population control thing.</font color=blue>[​IMG]
  8. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I have this problem. Pushing the button works every time.
    90K5
  9. Cusm
    Cusm 1/2 ton status
    Feb 25, 2000
    360
    OK
    I have this same problem, and then another, or an extension of this one. If you manually push the knob down, you must push the outside button to unlock. I can use the electric locks all day and it won't stick.
    My question is, Is replacing the external door handle the fix for this? I would like to fix this problem once and for all, or at least the next 20 years.
  10. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Mine does this on the drivers door, just push the button then it should unlock.
  11. Razorback
    Razorback Registered Member
    Oct 16, 2000
    10
    I missed your post on the tailgate. How did you get it open? I can't seem to unlock mine from the outside. I can roll the window down from the front control and then use the handle, but the keyhole just doesn't do squat. I have tried WD40 and lithium grease in the key hole and I even tore the tailgate open and greased it up like a pig. I was going to remove the lock, but the window complicated matters...anyone been there?
  12. bandit
    bandit 1/2 ton status
    Mar 4, 2001
    690
    Ellensburg Washington
    ok heres some answeas on stickey door locks =-) liek the rest have said try opn it from teh out side then once you push the teh dorr latch on teh out side reach in side an try unlocking it 9shoudl work not sure why but alot of chevys do this on the passenger side) on teh tail gate most chevy balzer iv been around you ahve ot roll the window allteh way down the slam on side or the other or my be both then pull open does that make sence ??
    AJ
    (Your right i dont understand the jeep thing)
  13. dyeager535
    26,982
    191
    Mine won't open either from teh key, even though I too tore it down, replaced the lock cylinder, cleaned contacts, etc. Yesterday i forgot and tried it from outside and it moved about 1/16 of an inch. Gonna have to tear it down again, I assume something in the lock cylinder/switch isn't making good contact, especially if the inside switch works..it can't be grease/motor related, it HAS to be in the rear lock cylinder mechanism
    Dorian
  14. 1990SilveradoK5
    Jan 2, 2001
    185
    Napoleon, OH
    It only does it every couple weeks, as I do not use that door much. Next time I will try the outside button while keying in. I think I tried it last time but I am not sure.
    Keith
  15. 1990SilveradoK5
    Jan 2, 2001
    185
    Napoleon, OH
    I thought I would never get the tail gate open but the other day It opened up from the inside. Have not had the chance to screw with the key hole yet. Right now I can not even get the key to slide in.
    Keith
  16. flcpl4fn
    flcpl4fn 1/2 ton status
    Jan 9, 2001
    194
    Florida
    Boy, I must be the lucky one. All of mine work great, from the inside to the outside, with the key and button. Well I had better know on wood that it keeps working. lol
    '85 Jimmy in Jax, Fl
  17. 1990SilveradoK5
    Jan 2, 2001
    185
    Napoleon, OH
    Did it again and the button thing worked.
    Thanks, it will give me time till I have to work on it
    Keith
  18. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    On my 87 all I have too do is push in on the button. Everything works fine again. Not sure whats wrong.
  19. loudandproud
    loudandproud 1/2 ton status
    Jun 27, 2000
    451
    Ham Lake, Minnesota
    I had that same problem with my lock today. I usually just fix it by pushing the black button and it works fine, but finally the black button trick didn't work. So it was time to remove the door panel and tackle it from the inside. I sprayed everything down with WD40 to clean it out really good, and finally after a while it cleaned out all the junk built up on everything, I still have to lube it up with some grease, but the WD40 did a good job cleaning. Now the lock works really good. I have had to take my door panels off about 6 or 7 times now in the past week, so I feel like I am an expert at doing it now.
    DOOH!![​IMG]<A target="_blank" HREF=http://loudandproud.coloradok5.com>http://loudandproud.coloradok5.com</A>
