Doorless question
Discussion in 'The Garage' started by 85 Jimmy, Jul 20, 2006.
  1. 85 Jimmy
    85 Jimmy Sheepdog Premium Member
    Dec 31, 2005
    1,913
    69
    Gulfcoast
    for you guy's that go doorless my question is how do you take them off and put them on by yourself?
    i already have the pins and everything b/c i've done it before, but it's a pain to do it by yourself and i was wondering if ya'll had any tricks?
  2. sarasotausmc
    sarasotausmc 1/2 ton status GMOTM Winner
    Dec 16, 2003
    769
    Jacksonville NC
  3. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    Before I just cut'em off for good I used to muscle it up and get 1 of the top bolts in and have a big jack to balance the corner so you can line it up just right. Thats my ghetto way of doin it.
  4. 85 Jimmy
    Dec 31, 2005
    1,913
    69
    Gulfcoast
    i've already done the quick release hinge pins... the question is how do you guys take them on and off by yourself, if you've never picked these doors up, they're pretty heavy.
  5. mrk5
    Apr 20, 2004
    12,332
    1,040
    Northern Colorado
    Sounds like you might need to hit the weight-room. :wink1: I prop it up on my leg and get it lined up.
    Now if you have electric windows, the door would be heavier because of the electric motor. Mines a manual crank and that makes a difference.
  6. balterbuilt
    balterbuilt 1/2 ton status
    May 10, 2004
    385
    Santa Rosa
    i always have someone help me, those htign are big heavy and akward. Wouldnt' want to screw teh door up by dropping it.
  7. 85 Jimmy
    Dec 31, 2005
    1,913
    69
    Gulfcoast
    i do need to hit the weight room :doah: , and i prop the corner of my doors on my leg to get it lined up also... and yes i do have power windows...
  8. greyhoundjc
    greyhoundjc 1/2 ton status
    Jan 23, 2005
    127
    Georgia
    I have full electric doors and I've been toying with the idea of making some kind of dolly that could be used to help remove/install the doors as well be a place to store them while they are off. It would have a roll around base and some type of stand that would hold one of the doors on each side. Hopefully it would be able get them pretty close to the hinge holes for re-installing. It's on my truck project list along with about a hundred other things.
  9. mlaux
    mlaux 1/2 ton status Premium Member
    Oct 22, 2000
    141
    9
    Rigby, ID
  10. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    That worked great for me, till I got 40's. I am only 5'6"
  11. vortec
    vortec 1/2 ton status
    Jul 22, 2004
    1,472
    fort worth, texas
    last time i put mine back on, i held the holes approximately aligned, then stuck undersized bolts (4 total) in the holes, to keep them lined up and take some weight. then, i went back and slid the pins in place of the bolts, realigning he holes as i went. only took a few minutes. way easier than putting the top back on by myself.
  12. 82K5_6.5L
    82K5_6.5L 1/2 ton status
    Dec 4, 2002
    439
    Tucson, Az
    the few times i have had to do it myself, i grab my high-lift, jack it up so it holds it a little bit, get the top bolted back on and then the bottom. i've taken them off that way too. works pretty good. ;)
  13. vortec
    Jul 22, 2004
    1,472
    fort worth, texas
    i think the doors fall into the same category as the top. once you get them off, it's much easier to just leave them off for a while. i may be flamed for saying this, but jeeps are definitely better in that respect. removing and installing those doors is easier than changing a tire. that's not enough to make me a jeep fan, though. not even close
