doorless
Discussion in 'The Garage' started by 91_blazer, Jul 13, 2004.
  1. 91_blazer
    91_blazer Newbie
    May 8, 2004
    4
    ontario
    i want to make my doors come off like a jeep cj,yj,tj how would i do that to my 91 S10 /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/peace.gif
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    unbolt them, other wise make all custom mounts.
  3. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
    Your tagline is correct: I don't understand Jeep things.
    That said, do a search; you'll find lots of posts and pix -- some by me even -- showing how to redo the hinge pins on K5's to make them quick-release.
    I'd hazard a guess that you could do something similar to your S-truck.
    -- A
  4. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I did it on my full sized. I used a 3/8ths rod in place of the pin. The upper one actually has to be put with the clip on top when the door is on.
  5. chevy17
    chevy17 Registered Member
    May 26, 2004
    9
    hey i live in illinois and i was just wondering if there was a law against that? /forums/images/graemlins/confused.gif
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Why would there be? Jeeps do it all the time.
    Just wear your seatbelt.
  7. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    Oregon law (or a rule since no one inforced it) is that jeeps have a lip in the door jamb (floor is lower) so nothing can roll out. The K series floors are flat s if the police want to be picky I'm sure they can make soemthing up, otherwise go for it!. I plan to take my doors off here but I built a 2.5" drop when I swapped the floors.
    PS more often then not the cop will site you for not having the side mirrors then he would for not having the door.
  8. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    I ran mine without doors for 2 months and had no problems with the police. One thing of advice would be watch where you put your stuff, I lost a couple of thermoses /forums/images/graemlins/eek.gif
  9. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    I remember back in the 70's that there was a company that made a fiberglass door piece that was to make them more like a jeep with the floor board having a lip that went up by the seat.
  10. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    drool over your blue k5 /forums/images/graemlins/bow.gif
    I love that sexy stock front end..reminds me of theis one truck I once saw /forums/images/graemlins/whistling.gif
    [​IMG] /forums/images/graemlins/doah.gif
  11. Bone85K5
    Bone85K5 1/2 ton status
    May 7, 2000
    436
    Columbus, Georgia
    real dumb question here but here goes:
    How does one remove doors on a k5 with power windows and locks??
  12. mud390
    mud390 1/2 ton status
    Oct 31, 2002
    1,210
    Little Rock, Arkansas
    My K5 doesn't have power windows or locks, but the easiest way I can come up with is cut the wires and put a plug right there that is easily accesable. Just make sure you get all the right wires where they need to be and everything should be honky doory.
    Kris
  13. Bone85K5
    May 7, 2000
    436
    Columbus, Georgia
    so do i remove the entire hinge assembly? or just pull the pin and see what happens? It looks like there is a little tack weld niplle thing on the top of the pin making the pin stay in btw the hinges.
  14. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Remove the entire hinge assembly if you don't want them showing. The part that looks tack welded is the nut that holds the bolt coming in from the inside. If you look under the dash on the side where the bolt would meet up, you will see a rubber plug. Pop that out and stick a socket with an extension on it and unscrew /forums/images/graemlins/grin.gif
  15. Bone85K5
    May 7, 2000
    436
    Columbus, Georgia
    Thamls man for the info. Any ideas on how to "unplu" the wiring harness for the power locks/windows without cutting them. I would like to put these back on someday..aka winter i guess.
  16. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    The pass side is easy, the plug can be accessed by removing the glove compartment door. Should be close to the wall on right. It is just a clip than can be unlatched w/ a flathead. The drivers side wire is a little harder same clip just not easily accessed. I had to dig my hand up through the wiring while tugging on the wire coming from the door to find which one. Then while your upside down sweating in the 110 degrees heat you will try to unlatch the clip with one hand /forums/images/graemlins/grin.gif I have done it this way twice. After you have done it once it is easier the second time.( I just noticed that you have an S10. I am sure the wiring might be the same though, sorry /forums/images/graemlins/tongue.gif)
  17. Bone85K5
    May 7, 2000
    436
    Columbus, Georgia
    mine is a 85 k5..sorry for the mixup..so you saying this is how u can do it for a k5??
  18. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Yes, mine is an 85 also, so it should be the same /forums/images/graemlins/waytogo.gif
  19. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i called the PD here and they said its illegal, they will bust you for it here, and maybe all across the state ff you remove doors, they said its lessens factory integrity and safety of the cab
    jeeps are a whole different ballgame though, they coem from factory alot with removeable doors
    doors that bolt on like gm truck doors are techgnically non removeable
    it sux
    those of you who live where laws are lax like this are lucky as hell, but may try it with pins and some other mods maybe, but im sure ill be busted pretty quick here, they are a PIA here,
  20. Bone85K5
    May 7, 2000
    436
    Columbus, Georgia
    Georgia laws are a joke. unless you are blingin with a real loud stereo and weed smoke flyin out your ok.
