Doors have trouble unlocking
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Jishory, Jan 4, 2006.
  1. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    is there anyway to make it so doors wont lock and trouble unlocking again, easily? cover eveything in grease inside? i cant wait till summer rolls around so i can lose em again
  2. lamberthkp
    lamberthkp SITFU Premium Member
    Jan 17, 2005
    1,468
    16
    West TN
    what do you mean ? mine does something wierd alot i will put my key in and it wont turn but i can push the button in and release it and then turn the key it will unlock, it does that about 50% of the time . is that what your talking about?
  3. Jishory
    Jan 8, 2002
    1,367
    Palmdale, CA
    sorry i should have been more specific, when its unlocked and i close it(slam it) its fine, i lock it with the key and it unlocks fine but if i close it while the door is locked or drive around with it locked it wont come unlocked. i used to be able to bang on the door and wiggle the key at the same time to get it unlocked but now the driver side door is stuck locked pretty damn good
  4. onlychevy6
    onlychevy6 1/2 ton status
    Mar 29, 2003
    1,293
    Hockley, Texas
    just dont lock your doors. LOL... other wise replace the lock cylinders. would be my best guess.
  5. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    its probly the locking tab on the cylender is miss aligned.
    just leave it unlocked if they take your truck Iam sure thell bring it back :p:
  6. Jishory
    Jan 8, 2002
    1,367
    Palmdale, CA
    this weekend ill see if i can get my driver-side door open... should be interesting if i have to go to plan b on that
    you back in town domonic?
  7. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,075
    486
    Grand Rapids area
    Mine does that too, I have been meaning to tear it apart.
  8. FlatBackBlazer
    FlatBackBlazer Registered Member
    Feb 8, 2005
    21
    Spencer, Ma
    Door latch problems
    I had my drivers door sticking sooo bad after an ice storm that i managed to get in the pass. door , sit on the console , hold the lever back , and kicked with both feet to open it and it wouldnt budge. Being late for work mind you , I got soooo pissed i got out with a tire iron and pryed the door away near the latch( after whaling the crap out of the outside of the door with the iron) :doah: and had to cut the striker bolt off with a sawsall!! And they werent even locked!!! I made sure to use plenty of white lithium grease on the bear claw latch and key cylinder when i put the new door in ! Also try messing with your door hinges to get them to align to the striker bolt a lil better . THere could be pressure on the the latch thats making it not want to unlock . Well thats my 2 Cents hope it helps you , if not makes you laugh !:haha:
  9. MuddQueenK5
    MuddQueenK5 Registered Member
    Oct 15, 2005
    84
    Glenside, PA
    Mine does the same exact thing, upon further inspeciton it seems that the button on the handle doesn't come out all the way. I just hit/pound down on the door handle over where the button is. After about three to four good hits I can unlock it just fine. It has worked for me everytime...
  10. Jishory
    Jan 8, 2002
    1,367
    Palmdale, CA
    ok i got the door open, pried someting in there that the locks connect to and it unlocked but i locked it again and now it wont unlock, luckily its still open but what do i replace?
  11. alf4444
    alf4444 1/2 ton status
    Nov 1, 2002
    2,051
    T-ville, ut.
    Door locks:confused: What are those:D I don't even know where my key is:doah:
  12. Jishory
    Jan 8, 2002
    1,367
    Palmdale, CA
    try living outside of la, the crime here is horrible
  13. alf4444
    Nov 1, 2002
    2,051
    T-ville, ut.
    I was in palmdale for a couple days last aug. didn't seem like too bad of of a town
  14. uberbeans
    uberbeans 1/2 ton status
    May 14, 2004
    564
    Jacksonville, Florida
    I have the identical problem. I didn't have the problem when the lock cylinders were in my previous doors but now that I installed them in the new doors about half of the time it wont unlock. It becomes so stiff that the key actually starts to bend/twist. The lock button begins to move but doesn't come up Any ideas?
  15. dleroy43
    Jul 22, 2002
    1,517
    Martinsburg WV
    I help jistory fix his with a little wd40 inside the door lock area
  16. SUPER'BURB
    SUPER'BURB 1/2 ton status
    Jan 9, 2005
    929
    Mountain House, Ca.
    My brother is still waiting for that. It might happen it's only been 2 yrs.
  17. dleroy43
    Jul 22, 2002
    1,517
    Martinsburg WV
    you haven been in josh's truck...they would bring it back :ignore: :haha:
  18. SUPER'BURB
    Jan 9, 2005
    929
    Mountain House, Ca.
    :haha: Thats cold:haha:
  19. shawnboy
    shawnboy 1/2 ton status
    Jun 22, 2001
    468
    Toronto, Canada, eh.
    After a while, even weasel piss(wd-40) and flicking the door knob doesn't get you into your locked rig. Now is the, sigh, time to rip into it and get it fixed.
    My project for the weekend.
