Doors
Discussion in 'The Garage' started by RatMan, Mar 26, 2003.
  1. RatMan
    RatMan 1/2 ton status
    Jul 27, 2002
    270
    Marietta, Georgia
    the doors on my k5 dont close all that good. most of the time they end up in that 'half-closed' position until i notice and slam them shut. is there any way to make it easier to close them?? tia
  2. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    The striker bolts or latches are probably worn out.
  3. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    just remove them you don't need'em
    /forums/images/graemlins/thumb.gif
  4. crwln73
    crwln73 1/2 ton status
    Sep 6, 2002
    362
    Clovis,Ca
    Doors! Who needs doors they just hang up on rocks.Doorless is ther only way to wheel.You have alot better visability and just that much less sheetmetal.
  5. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    as stated above, maybe also the hindge pin
  6. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    I had the same problem on mine. Got 2 sets of door pins from NAPA for like $12 a piece and fixed the sagging door not closing problem.
  7. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    May also be missing the hinge spring that holds the door open. Believe it or not, it really does help a lot to close the door.
  8. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    My problem was the striker bolt was too high, after I replaced my door hinges.
    I did't know the striker bolt could be moved up down and inside outside - a little bit.
    That's all I need. Now my driver's door closes SO easily, I have to keep checking it to make sure it is fully closed. Where as before, I would ALWAYS have to open it and SLAM it shut to get it to close on the second latch.
    BTW: I left it like this for about three years. My door latch mechanism wore through the top, and my striker bolt area on the body got all cracked from stress.
    I took my door apart, took out the mechanism. Greased it all up, put in a new door striker bolt after I welded up all aroud it on the body.
    I still need to raise the entire door about 1/4" and then move the striker back up a 1/4" and it will sit like it was new. Well - someday I will do that. But I anticipate running topless, doorless, and tailgate-less this summer.
    I am still not sure what I will be doing about a side-view mirror though.
