dork york Q
Discussion in 'The Garage' started by Roz, Nov 16, 2005.
  1. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    is there any mods to the york it self that should be done? someone had mentioned something but i cant seem to find any info other then the install stuff. i have mine ready to go but not shure if the compresser is good to go to charge the system.
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Check it out!!!
    This link has the oil port mod I was telling you about just read through it.
    here too
    This link has some kewl stuff on the york also.
    Ira
  3. MrArmyAnt
    MrArmyAnt 1/2 ton status
    Dec 29, 2004
    662
    Texas, Kick a$$! (Grapevine, DFW; also Norman, OK)
    wth is a york?
  4. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    sweet, gonna do it so i can try her out :)
    TY!!
  5. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    follow the link
  6. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    A york is a brand of AC compressor that people use for an onboard air compressor since it is a self contained unit meaning it has a crankcase of oil and has an inlet and outlet for making air.
  7. MrArmyAnt
    Dec 29, 2004
    662
    Wait, why couldnt you get like a 6 hp lawn mower motor and hook it up? with just a stand alone tank? you could have your own gas powered compressor? anyone recomend better compressors for this?
  8. sandawgk5
    Oct 28, 2003
    6,881
    This is for On-Board Air. I suppose u could lock the clutch in somehow and run a belt drive from an engine and have a shop compressor if you wanted.
    These compressors are driven by the engine for air tires, running air tools and other trail needs for air.
    Ira
  9. driney
    driney 1/2 ton status Premium Member
    Jul 6, 2001
    699
    7
    west central illinois
    Somewhere I saw someone elses oil mod where they pulled the head and put a screw in the upper end of that oil passage. Supposedly a lot easier and he got the tip from someone at Kilby Enterprises so I would think the advice should be good. I haven't checked into this myself, does anyone know why it wouldn't work?
    Edit: found the link
  10. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Because it would be more difficult to fit under the hood and take out on the trail. :D Look here to get an idea of what we are talking about.
