Double Cardan Conversion Kit
Discussion in 'The Garage' started by buffcc1, Feb 25, 2006.
  1. buffcc1
    buffcc1 Registered Member
    May 30, 2005
    42
    Wichita Falls Texas
    Has anybody ever used this before and if so should i buy it from the site or is it easy enough for a local driveline shop to make?
    http://www.4xshaft.com/double_cardan.html
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I'm always a fan of used parts....
    You can do a NP205 CV from 78-79 Bronco parts.
    Or find a 70's RWD Caddy for the CV slip shaft - for any 32-spline slip-yoke t-case.
    Then you are just having a shaft shortened, spliced, or re-rubed (as usual).
  3. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    I have a caddy shaft here, thought it would be a great idea, angularity is minimal at best, no way I could run it on my rig, with only 4" of lift. HAD does a 32 spline flange, and then you use a ford superduty front driveshaft CV joint (1350's). Works great. Easy to drop the whole driveshave at need as well
