Double Cardan shaft
Discussion in 'The Garage' started by BigCountryx, Jun 12, 2005.
  1. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    I know a SYE would be best but if I can get a Double Cardan Rear Driveshaft made locally for a decent price, would it be sufficient with my NP241? I will have about 7" of lift in the rear.
    The lower shaft in this pic is what I am refering to
  2. blazerpro79
    blazerpro79 1/2 ton status
    Jan 4, 2005
    528
    Simi Valley, CA
    i dont understand why it wouldnt be if it is made for your truck.
  3. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Well, the problem is that with that kind of lift and such a short shaft you're putting the driveshaft at a steep angle. When the suspension compresses it's trying to slide that shaft in at a severe angle. It puts a lot of stress on that tailhousing.
    I haven't seen a broken 241 yet but I have seen a broken 208. It's kind of a kick in the teeth when you bust the back half of your transfer case off.
    If you had more wheelbase I wouldn't be worried about it. But I know that right now with a 2" longer than stock K5 driveshaft and my yokes near their limit at full droop you can see the pain the tailhousing goes through.
  4. blazerpro79
    Jan 4, 2005
    528
    Simi Valley, CA
    i would think that being a cv at the tcase end of the driveshaft it should be okay... :confused:
  5. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Think about it a little longer. The angle is actually STEEPER because of the CV part shortening the driveshaft. It is a lot of side load on the tailhousing.
    All the CV part does is alleviate the ANGLE of the UNIVERSAL JOINTS.
