Double Cardan U-joint??? or wha
Discussion in 'The Garage' started by 1985K20, Jan 30, 2005.
  1. 1985K20
    1985K20 1/2 ton status
    Jan 11, 2005
    191
    Quebec,Canada
    Ok, here's my story: my truck's a 1985 3/4 ton 4x4(auto), with a np 208 for the tc. Until this morning the 4WDriving was ok. What happened is that i pulled in my uncle's driveway wich is full of snow so i pulled on the stick to shoved her in 4HI, everything was ok, til i got back on the dry pavement(back in 2HI), i start hearing a not quite banging noise...more like rubbing noise coming from the front end.I put 2 new ball joints,2 new f. axles u-joints,grease her up plenty all the time.lots of fluid in the f. diff.
    the only thing i noticed before was a shimmy starting around 40 mph with the front hubs locked, wich is cause by the little play between the u-joint and the frt. diff. yoke.
    But that still dont explain that rubbing noise who started this morning.could this
    be the Double cardan u joint at the tc??? one of my friend told me something about a ball in there?!?! any ideas guys?:(
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    it could be the ujoints in the CV are WAY loose and its rubbing on the crossmember.
  3. 1985K20
    Jan 11, 2005
    191
    Quebec,Canada
    I'll check that tommorow, thanks for your response
