Double Cardigan driveshafts and 208's
Discussion in 'The Garage' started by jjlaughner, May 7, 2004.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Double Cardigan driveshafts and 208\'s
    Are the CV or double cardigan driveshafts a good fix for small vibes?
    In my DD, 350/700r4/208/10bolts I have my Tcase lowered, 4" rear springs zerorate, and I think its a 3-4degree shim. The pinion angle on the axle versus the drive shaft is good (couple degrees) but the driveshaft at the tcase is still making a pretty good drop. I get some vibes during hard acceleration so I'm guess that has a little to do with axle wrap. It doesn't do it all the time it seems to come and go. I haven't changed the ujoints recently but I dont have the extra cash to toss $10-15 here and there. /forums/images/graemlins/tongue.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/dunno.gif
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Re: Double Cardigan driveshafts and 208\'s
    but you have a couple hundred for a CV shaft? What about the output bushing on the 208? do like you would do on a U joint to check it, wiggle the output yoke around. See if it does anything. I had this problem too, vibe never went away and mine wasn't lifted. My pinion bearing was shot. Wobble like mad. Not saying thats your thing but definetally check for wear in all the rear driveline parts before dropping the dough on a CV shaft. You shouldn't need a CV shaft with only 4" of lift.
  3. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    oh and its double cardan joint /forums/images/graemlins/wink.gif cardigan is some sweater or something.
  4. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    No I dont really have the money for a new shaft, but I dont want to do a bunch of it might be type fixes /forums/images/graemlins/dunno.gif I done that a couple years ago and ended up replacing good parts and wasting alot of time. IF I do it I would just save up the $15 here, 20 there and buy a new driveline (esp since I'm going to be swapping in a 14bolt soon /forums/images/graemlins/grin.gif)
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Have you clearanced the CV to keep it from binding yet?
  6. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    /forums/images/graemlins/thinking.gif no that's in the front, althought there is some vibe up there also /forums/images/graemlins/whistling.gif
  7. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I am running 2" taper blocks (4*) and 2" addaleaves and I have no vibs. I am not running a top, tailgate, or rear seat either so I got some extra lift there. I do have a 14bff though which moved my pinion forward 1" or so.
    I had vibs until (this may sound crazy) I raised my tcase back up to stock height.
    Check the angles on the driveshaft and try and match them up. Make sure to account for the pinion trying to rise up under power.
    Harley
  8. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    I had really bad vibes out of my 208 when I installed the echobit shackle flip in the rear. I put in a cv shaft and havent had the slightest problem since. The rear isnt even shimmed.
    -harrison
  9. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    That is because the shackle flip basically points the pinion straight at the case which is ideal for a CV drivshaft.
    P.S. I am running a stock rear driveshaft with a #447 conversion joint in it. Forgot to mention that in my post above.
    Harley
  10. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Hey guy here's what I think is going to happen when the 14bolt goes in I need order some of those 2" tapered blocks. Then the zerorates I have in there now I will need in the front of the project truck. Right now the silver truck is squating just a little. I have 4" springs up front that gave me 7" of lift over the stock springs, the rear 4" springs gave me 4" of lift, plus the zerorate. Once the 2" tapered block go in it will sit level so i guess I need to figure out what taper I need too /forums/images/graemlins/tongue.gif
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Sorry to mislead you, I thought you were talking about the rear. With 120" of WB I've fortunately never had rear shaft issues.
  12. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    I'm talking about putting one in the rear if it does ease the vibe woows.
    The front has a DS spacer and in 4wd does vibrate a little but I haven't clearenced it like you mentioned. /forums/images/graemlins/thumb.gif
  13. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    -harrison
    Thats the stories I want to hear /forums/images/graemlins/deal.gif
  14. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Are you sure it is not binding due to angle? You can shim all you want, but if those yokes are hitting each other you're going to feel vibes. You might just have to clearance the yokes a tiny bit to keep it from binding. /forums/images/graemlins/grind.gif
    Binding is about the quickest way to self destruct your driveshafts. No matter how big your u joints are, they can and will rapidly self destruct if you allow them to bind. That includes the front CV.
  15. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    You do realize though the reason Harrison had vibs is totally different then yours. You don't have a shackle flip, you said you have 4" springs.
    A shackle flip rotates the axle upward and causes the pinion to point at the transfer case. That is the ideal for a CV driveshaft. You do not have this ideal state. You would have to create it.
    If you want to go spend alot of money on a CV driveshaft be my guest, but I am telling you you probably don't need to. You are still going to have to mess with the pinion angle and raising and lowering the tcase until you get it to point right just like without a CV shaft.
    A CV shaft isn't a cure all. Plus why would you want to spend more money on an expensive driveshaft. If you break it you have to buy another.
    I am running a setup similar to yours and I run stock driveshafts. They are alot cheaper and easier to find if you break one. I picked up my spare rear driveshaft for $40. Do that with a CV.
    Harley
  16. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I agree totally. I don't run a CV shaft and I wouldn't unless I absolutely had to.
  17. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    This is on my DD, I doubt I will break the driveshaft unless I do get around to my motor build next summer.
    I do relize he has a shackle flip, but I'm also running shims, he's not. I still need to lift the truck int he rear, thus the 2" tapered blocks that I still need to find the correct degree for those. I have no doubt that the rear angle to the axle is ok, its the angle from the tcase that I think is the probley, the more expensive driveshaft will allow more of a drop at that point, a STOCK driveshaft doesn't. Besides I have a driveline guy that can trim a couple inches off my driveline and put in the double cardon section in a decent price. This truck sees alot of highway use and stop and go street driving.
  18. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    What degree shim is 3/8" at one end and comes to a point at the other?
  19. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    If it is binding your engine has enough torque at idle to destroy the u joints. You don't have to have a special motor to break a driveshaft if it's binding.
