double cardon cv ball kit ?
Discussion in 'The Garage' started by Thumper, Jul 19, 2004.
  1. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    Well, I am about to undertake an adventure... replacing the entire ball/ spring/ u-joints in my front driveshaft double cardon cv. Any pointers? Any warnings?
    Mike
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    its a pain it the A$$ is you don't have a press. you need to either heat the caps up to melt the plastic holding them in or press them out. plus its easier to press the caps in while holding everything else other than having a helper hold the stuff while you beat it in. just my opinion /forums/images/graemlins/waytogo.gif
  3. Thumper
    1,582
    Alberta Canada
    Well, Im back. It wasnt bad. I do have a press, and had a helper of a sorts. The only issue was that I busted the H coupler trying to get the first u-joint out of it. So, I had to strip apart my spare which hadnt been apart before. I heated the caps, and got the plastic out and everything went together pretty good. Now I can put the shaft on tomorrow and will be back to fully operational 4WD! /forums/images/graemlins/smile.gif
    Later
    Mike
