Double Checking Information
Discussion in 'The Garage' started by Quackaddict, Apr 24, 2006.
  1. Quackaddict
    Quackaddict 1/2 ton status
    Apr 2, 2006
    160
    Glenn Heights, Texas
    Yes this might seem like a newb type question but I did search. I really only need one answer. I got an 80 K-5. I looked at the Tech section and it says Dana 44's were up front until 77. It says they used the 10 bolt starting in 83.
    Now I looked close at mine and I noticed it has a drain/fill plug on the front of the diff cover. Does this mean I have a D44? anything else to look for. Trying to figure out what I have.
    Speaking of this question might want to throw a sticky somewhere with real pics of the differnt axles we all have?????
  2. duanel
    duanel Registered Member
    Feb 20, 2006
    59
    spokane WA
    the dana should have the model number stamped on the web or the nose, in my case it is on the drivers side bottom web 44-dcf. 44 being the model number. and the front diff shown in my haynes deffinatley aint a dana 44 as its drian plug is on the diff case not the cover.
  3. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
  4. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    interesting....because of this i went and took a look at my 83. I have no fill plug in the dif. case, and by the axle identification guide, i do infact have a 44 infront, its not the round/oval case like 10b's.
    wtf?
  5. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    Quick and easy way to tell a 10 bolt, it has "ears" on the either side of the pumpkin, below the cover. A Dana 44 has a plug in the cover, and like duanel said, it will have a 44-something at the 5 o'clock position, looking at it from the front.
  6. lockedup72
    lockedup72 Registered Member
    Nov 22, 2005
    61
    mobile,Al
    i thought the easy way to tell is that all dana axle covers are straight(vertical) on both sides.
  7. Citizen Rider
    May 5, 2005
    1,415
    Plano, Texas
    i only found #'s on the back of the casing by the yoke on the pass. side. i cant read it cause of the gunk.
  8. fourwheelerjeff
    fourwheelerjeff 1/2 ton status Staff Member Moderator
    Nov 16, 2001
    3,419
    6
    meadow, tx; in the boonies
    i am pretty sure you have a 10 bolt
  9. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    yeppers... been a while since I've seen one, but all signs point to a 10b.
    j
