Double crossover?
Discussion in 'The Garage' started by PsychoticDeadGuy, Oct 16, 2005.
  1. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    edit: go to post 2 in page 3!
    Anyone get the new Peterson's 4wheel and off road magazine? there is a steering article and they talk about different crossover steering systems. the double crossover has a link from the steering box that goes to a bellcrank on the other frame rail and then from there it has a link that goes to the driver side knuckle with a tie rod. you wouldnt need the flat top knuckle for the passenger side at all. how wouldw you set up the bellcrank system on a K5? what kind of truck could i find this type of set up on? any one ever do it? oh, and the reason i am asking is because i want to do a cheap crossover for my 10b until i find a d60. and i cant find a flat top knuckle for the passenger side.
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    IIRC, FJ40 Landcruiser has a steering bellcrank. I think it still steers the passenger knuckle though. Might still be worth a look for ideas. :thinking:
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Stephen from ORD has run this system on Wally for years.
  4. PsychoticDeadGuy
    Jan 8, 2005
    753
    does anyone have any pics of the double crossover on Wally? i cant find any pics of it...
  5. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    right off ORD's site...
  6. PsychoticDeadGuy
    Jan 8, 2005
    753
    is everything backwards? because of the full hydro steering system?
  7. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    it isn't full hydro steer(that is a steering box). Why they ran the steering box down there, I forget, but it was what was done.
  8. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    ok, so what makes that so much better than normal cross-over?
  9. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    They put there box up there because with the linked front when the wheel was turned and stuffed it would make serious contact with the box and hydro fittings. As for any better than regular I think it would end up being more expensive in the long run with the extra fabrication and parts required.
    Ira
  10. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    if you want cheap crossover run a draglink to the hole in the tierod. i have seen it done and its supposed to work real well (and its cheap) ill try to find it.
  11. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    great for coil sprung or spring under setups, not for us...
  12. 79k20350
    Nov 22, 2004
    7,757
    Ct
    Its been done by a ck5 user, the angles are not perfect, but it get the job done. Its much better than the stock setup for sure, not as good as a standard crossover setup but its cheap. why spend a ton on something you know your going to get rid of anyways?
  13. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    what do you mean spend a ton on something you know you are going to get rid of?
    Yes I forget who did it but I remember its been done by a Ck5er. He liked it but I still don't think it a great option.
  14. 79k20350
    Nov 22, 2004
    7,757
    Ct
    he said he wants to do a cheap crossover cause he knows hes goin to be getting a d60. i dont see a problem with it. many vechicles (full size) come from teh factory with this setup.
  15. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    arms aren't expensive, expense is in the knuckles. Which you can resell to someone else. Drag link will work, D44/10 bolt or D60 doesn't matter there.
    I think properly designing and fabricating the "double crossover" would be more expensive and time consuming then you think. Would want to tighten up the front frame rails too, since now you are relying on both sides of the frame rail for steering.
    What I saw in that article that I liked was the idler arm steering.
  16. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    How'd I know that pic was coming :D I bet it would come closer to working if you tied into the tierod where the stabilizer hole is instead of where the tierod ties into the knuckle like you have drawn. Would have to insvert the tie rod end for end to make it work. :dunno:
  17. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    right thats how it was done when by a member(maybe former member). I think it was Tweetysaurus, haven't seen him in a long time though.
  18. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
  19. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    why would you say that? the leverage would be minimal if non-existent since the force enters and exits on the same plane. Force put in would be = to force put out. So actually I'd think you are placing all the force in both frame rails. Correct me if I'm thinking wrong. One thing I see that could be good is you could do a see-saw sort of thing sort of like this:
    0 <-pivot
    and use the bottom side for steering input and output and the top for moutning a hydro assist ram. Would place the weight a little higher then the usual setup but less plumbing and no chance of snagging a line.
  20. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    I just think it would be a split of force. all the force on one rail with one arm, add another idler arm, now you have 1/2 the total force on each frame rail.
