Double Flare tool...(need one)
Discussion in 'The Garage' started by SCJimmy, Dec 3, 2003.
  1. SCJimmy
    SCJimmy 1/2 ton status
    Mar 7, 2003
    406
    Simpsonville, South Carolina
    I need to buy a double flare tool for brake line work.
    I tried the Autozone "OEM" loaner tool, but the POS clamp block would not hold the tube tight enough to make the first flare. /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif
    I need to buy one ASAP, to modify my new In-Line tubing for my 14bff.
    I'm assuming I will need a standard tool, not a metric.
    Can anyone tell be where to buy a good one?
    /forums/images/graemlins/1zhelp.gif
  2. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Some Sears carry them but I don't think you'll find a 24hr drive thru window there /forums/images/graemlins/tongue.gif
  3. bowtiepower00
    bowtiepower00 1/2 ton status
    May 11, 2000
    924
    AZ
    If you're willing to spend a bit your local Snap-on man will have one.
  4. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I got mine from the local tool store for around $40.
  5. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    I got mine from Summit. $35 or so. I haven't used it yet, so I can't tell you how well it works.
  6. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Local auto parts store - mine was $30. Generic brand, but I can make some good looking flares. /forums/images/graemlins/thumb.gif
  7. florida4x4
    florida4x4 1/2 ton status
    Sep 9, 2002
    255
    Florida
    I tried the cheapo's but settled on a blue point from the snap on man. $85.00. I bet the ridgid that is available from home depot will do as good a job for half the price. The trick is to get the tube clamp on TIGHT so the tube dont move....
    Now if I had to do it all over again then I would get this:
    http://www.thetoolwarehouse.net/shop/MAS-71475.html
    It's only money right? /forums/images/graemlins/1zhelp.gif
  8. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    You could get either this one from Snap-on
    Description:
    Makes double or single flares on soft steel, brass, or aluminum tubing from 3/16" to 1/2" OD. Makes a smooth fitting, crack free 45° flare. Set includes five adaptors, yoke assembly, bar assembly, and handle. Plastic storage case included.
    Product Specifications
    Stock Number TF5
    Name Set, Double Flaring Tool
    Price** $40.05
    Or this one from Snap-on
    Description:
    Contains TC28C Tubing Cutter and a double flaring set with a flaring bar, rod handle, yoke, and 5 adaptors: 3/16", 1/4", 5/16", 3/8", and 1/2". Plastic storage case included.
    Stock Number TF528D
    Name Set, Tube Cutting and Double Flaring
    Price** $109.95
    DESCRIPTION Tubing Cutter/Double Flaring Set
  9. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    use a wrench or big pliers to tighten the autozone one up tighter than just by hand, this will hold the line
    works for me everytime
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yep I usually don't have a wrench handy at the counter so I use pliers. /forums/images/graemlins/smile.gif
    That tool works great when it's new, but when the knurls wear out in the holder part from too many customers using it without tightening the wing nuts, it's not worth a shi* so I damage them out so the next customer doesn't get that BS.
