Double Gasketed Headers?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BigBadBowTie, Jun 2, 2000.
  1. BigBadBowTie
    BigBadBowTie 1/2 ton status
    Apr 6, 2000
    160
    AZ
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Thought about it!
    We were talkin about this last month and someone had bad luck with that!
    I am going to use the THICK dead soft aluminum type gaskets from SUMMIT when I get the extra 40bucks for them. For now I have a headerleak that is not so bad but I can still hear it and I have the copper style......
    Good Luck
    Rock ON![​IMG] 72 K5 [​IMG] Led Zeppelin
  3. J.R.
    J.R. Guest
    instead of double gaskets,buy the very good pair of header gaskets and then buy the header bolt locking kit,i got mine from jegs,never had any prblems with leaks or blowing out a gasket.
    BIGBLOCK MAN
  4. 73/75 k5
    73/75 k5 Registered Member
    Mar 18, 2000
    38
    ca
    Me and my buddy's like to use two exhaust manifold gaskets put together for each header tube. I havn't had any problems with it and they are not that expensive. Just a thought.
    Later
    sean
  5. Bondo
    Bondo 1/2 ton status
    193
    Bath, NY
    I use double gaskets on the headers in my vette and have never had a problem.
    BONDO WILL FIX ANYTHING!!!
  6. Emmettology 101
    May 9, 2000
    8,126
    FL
    I spoke with a guys last week that had headers on a 400SBC in a K5 and he used orange gasket goop and hasn't had a leak problem. he has been using them for about 8 months.
    Mike
    82 GMC Jimmy "Emmett" "Built for function, not for beauty!"
    IN TOO DEEP Off-Road Club
  7. 87Blzr
    87Blzr 1/2 ton status
    May 24, 2000
    111
    This is going to sound crazy but I read it in a magazine that said racers do it and it worked. You can use the cheap paper style gaskets but soak them in the bathtub (so they sit flat) overnight. Then when you install them, install them while they are wet right out of the bathtub. Then start your engine and the exhaust form the motor will make them stick real nice. I used to blow out paper gaskets weekly until I tried this (too cheap to buy the aluminum or copper). I tried this on my 396 Camaro that has a 4 speed and 390 gears that see's alot of use and haven't blown out a cheap paper gasket since I did this last year sometime. Of course make sure your mating surfaces are clean and flat. The bolts with the locks are real nice too
    87 K5 Siverado, 68 SS 396 Camaro
