DOUBLE or SINGLE wide top for my 71 blazer?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by ak7, Mar 6, 2002.
  1. ak7
    ak7 Registered Member
    Feb 15, 2002
    57
    Hayward, CA
    I've got a 71 blazer in need of a new top. All that I have left from mine is the rear hatch which is in awful shape. I'm looking for a new top in the California area. Can anybody help?
    Can I fit both a single and a double wide on my blazer?
    If so, which one is better?
  2. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    Adam,
    The tops are "Single-Wall" and "Double-Wall".....and either one will fit on your Blazer. One way to tell which one it came with originally is to check the bedrails and see if it has threaded nuts installed along each side. If it does, then it was setup to use a Single-Wall top which bolts in from the top....if all you have is holes in the bedrails, you were originally fitted with the Double-Wall top, which is secured from underneath the bedrail.
    The question of which is better is debatable....I personally wanted a Single-Wall top because I remove it & install it every time the seasons change and I didn't want to have to remove the side panels to get at the fasteners. If you leave the top in place all the time.....the double-wall top has a more "finished" look on the inside, and may be quieter on the road due to it's construction.....
    Single Wall tops have 2 dome lights in them.....Double wall tops have NO dome lights.....that's another way to know for sure what you're looking at (besides the obvious bolts-down / bolts-up fastening method)
    Hope that gets you started...../forums/images/icons/smile.gif
  3. ak7
    Feb 15, 2002
    57
    Hayward, CA
    Greg72,
    Thanks... That actually helps me out a whole bunch. Only a few months ago all I knew about first gen blazers was they had a sweet body style and I wanted one. Now that I got one, I'm having a great time fixing it up and learning about em.
  4. ak7
    Feb 15, 2002
    57
    Hayward, CA
    The funny part about this whole thing.... needing a new top for my blazer. Well it wouldn't have been a problem if I would have checked to make sure it was bolted down when i trailered it home. hehehehhe... I lost it somewhere on the freeway between Eureka and Cloverdale.
  5. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    oohh...no way!I cringe at the thought.That sucks!
  6. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,259
    72
    Humboldt/Pacifica, CA
    There's a free top on the for sale board ... too bad it's in TX. I'll keep an eye open though.
  7. Benrs86
    Benrs86 Registered Member
    Mar 6, 2002
    15
    ouch that sucks. i know nothing about 69-72 blazers so this is probably a dumb question. my dad told me that only some had the removable top option and i said no way but he guaranteed me some could not be removed. are you saying they all are removable single or double wall? thanks,Ben
  8. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    69-75...full removable tops,all the way to the windshield.
    76-89 or 90...only the back half,from behind the front seats on back comes off.
    the rest are not removable.Some-one correct me if I'm off on the 2nd gen. years.
    The single or double walled tops only refer to the 1st generation trucks(69-72).Body style changed in 73 and so did the removable tops.
  9. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Maybe it is the difference that you have to take off the side panels to get to the bolts to remove a double wall top and to remove a single wall all you do is take the bolts out from the top?
  10. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Oh...welcome to CK5. Fill in your profile so we all know who you are.
  11. rampage
    Mar 20, 2001
    2,259
    72
    Found a top for you in Mtn View if you haven't found one already. Hopefully it's not spoken for already /forums/images/icons/smile.gif
    <a target="_blank" href=http://coloradok5.com/forums/showflat.php?Cat=&amp;Board=forsale&amp;Number=376873&amp;page=0&amp;view=collapsed&amp;sb=5&amp;o=&amp;fpart=1#Post377608> Top for sale </a>
  12. ak7
    Feb 15, 2002
    57
    Hayward, CA
    rampage,
    Thanks for looking out. I think its really cool how everybody on this message forum helps eachother out. I actually ended up finding a top in Stockton, CA not too long ago for $200. It was in great condition. Soon after that I bought two more blazers off ebay that both had a/c cabs and perfect single wall tops. Now it looks like i'm the guy with parts to sell... hehehe
    ak7
  13. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    I thought only 69 -72 had full convertible tops? but i see you post and there was a guy in the paper a while back that had a 75 full convertible for sale for 6500.00 when my wife asked me i told her it had to be wrong. guess i was wrong
  14. rampage
    Mar 20, 2001
    2,259
    72
    ak7, no prob ... glad you found a top to replace the one you 'accidentially' lost /forums/images/icons/smile.gif
    Yep, full convert. up through 75 ... unless someone hacked a half top Blazer and converted it into a full top. /forums/images/icons/blush.gif
