Double sided rear steering arms
Discussion in 'The Garage' started by 79chevyk10, Aug 4, 2006.
  1. 79chevyk10
    79chevyk10 1/2 ton status
    Dec 14, 2003
    612
    Central Coast
    Searching didn't yeild any info, so I thought I would bring it to you. I want to put the tie rod end behind the axle on my D60 swap so I can move the front axle as far forward as possible without any draglink interferrence. So before I call up WFO and order up the arms, I would like to know if there is any interferrence with the oil pan from the tie rod end. Specs will be 52's up front with zero rates. Thanks for any responses.
  2. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    In addition to input here, ask Trevor about it. He'll know and will give you the straight of it.
  3. 79chevyk10
    Dec 14, 2003
    612
    Central Coast
    Come aaahhhhhnnnnnn! No one is using double high steer arms. Talked to Trevor and we decided that should be no problem.
    I just can't believe no one on CK5 is running behind the axle high steer arms.:confused:
  4. BoondocK5
    BoondocK5 1 ton status Author
    May 13, 2006
    10,035
    63
    Salt Lake City, Utah
    Patience grasshopper,
    it's the weekend. everyone is out working on 'em, or wheelin 'em.
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    Or he can check the PBB guys as they use them more than anyone else here.
