Double stick 205
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by keith, Mar 15, 2000.
  1. keith
    keith 1/2 ton status
    1,158
    La Fayette, GA
    Still looking for info on how to adapt my 205 to a dual stick set up.
  2. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    You need to talk to David Schere. He's the ONLY one doing this now since Avalanch Engineering doesn't do them anymore. I actually sent mine (Avalanch shifter) up to David so he could copy it and he has actually improved the design.
    David Schere's email:
    ztrmower@netzero.net
  3. Boggin' Blazer
    Boggin' Blazer 1/2 ton status
    139
    Sunny State of Florida
    kieth
    i will be making them shortly. I will get in touch with you soon!!
    Thanks Shawn for the plug!!!
    David
    Drive It Like You Stole It !!!![​IMG]
  4. BIGRIG
    BIGRIG 1/2 ton status
    Feb 29, 2000
    488
    Independence, MO
    SORRY GUYS I GUESS IM BEHIND WHATS THIS DAUL STICK? ONE FOR LOW AND ONE FOR HIGH?
    MY DRINKING TEAM HAS A FOUR WHEELING PROBLEM!
  5. Shawn
    1,753
    5
    5280'
    The twin stick shifter can only be used on the NP-205 at this time. 1 shifter is for Hi-Lo. The other shifter is for 2WD-4WD. This lets you run in 2WD Lo for certain trails. I was also told you can run just the front (FWD) but I haven't tried it since my shifter is not installed yet. It's also easier to select the proper gear. My old 205 shifter is a pain to get it in the right gear.
    Shawn
    87 K5
