Double T/C Shifter Advantages???
Discussion in 'The Garage' started by trukman1, May 7, 2002.
  1. trukman1
    trukman1 1/2 ton status
    Mar 5, 2002
    129
    Ohio
    What is the advantage to double T/case shifters? I'm running an NP205 and don't really understand the big deal with the double shifters. (Everybody has to learn). Gary
  2. bigjbear
    Feb 18, 2000
    13,970
    449
    Marietta GA
    It allows you to have a 2LO - good for steep boat ramps and improves turnning with a locked front. It also gives the option of FWD only if the rear is broke.
  3. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    i get 2 lo with normal shifter, leave hubs unlocked.
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    i think that you can get a tighter turning radius with 'front drive only' in some situations.
    havent tried it, i like the speed you can grab 4lo with the factory shifter when that puddle turns out to be more then a puddle
  5. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    You can do a quick modify to the 205 to get a true 2wd low.
    One shifter and not have to mess with the hubs.
    To get the front drive only, then you need two sticks. And that has the benefit of tighter turning.
    Ken H.
  6. trukman1
    Mar 5, 2002
    129
    Ohio
    Thanks Guys! Now I'm sure there are those who find the twin-stick setup of great value. Personnally, I'm not going to be one of them. Just wanted to be sure I wasn't missing something I really needed. Thanks for the information. Gary
