double t case question!~!~!~!~!~!
Discussion in 'The Garage' started by TC4x4, Oct 9, 2006.
  1. TC4x4
    TC4x4 1/2 ton status
    Sep 12, 2006
    831
    Michigan
    Can anyone tell me what a double t case does and how it works and why is it better??/ thanks the mule
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Well, you actually only use the range portion of a NP203 case and then an NP205 behind that. The range portion gives you the choice of high range for a straight through gear (1:1) into the 205 or shift it into low range and "double" your 205 gearing.
    Now if you twin stick the 205 you can even have front axle only or rear axle only.
  3. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    it gives you 4:1 low range. not necessarily cheap, but very strong.
  4. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    it lets you have many more options
    2:1
    4:1
    or Front wheel drive only if you get the right shifter setup
  5. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    A doubler accelerates the inevitable progression from street legal K5 to full on buggy...:doah:
    Rene
  6. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Hmmm...all I have is a 241 and it still went pretty quickly. :p:
    More options for different situations.
  7. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    guess im screwed then....im building a doubler this winter:doah: :haha:
  8. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    kinda funny--mine actually has a sweet spot that I can use front digs only.:D
