Double Wall Hard top Bolt sizes?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Rhody, Sep 21, 2002.
  1. Rhody
    Rhody Registered Member
    Oct 8, 2001
    22
    Wallingford, WA
    I am about to put my hardtop back on. Unfortunately I no longer have the bolts or their sizes. Can anyone help please? Also, If I get the hard top back on, And I cut the rocker panels and boxes out. Will I have allignment problems and if so, What can I do to prevent the body from getting tweaked?
  2. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    good luck I never found them either..
  3. tp85
    tp85 1/2 ton status Premium Member
    Mar 14, 2002
    130
    Maryland
    I also have a double wall hardtop with no bolts. So I'd be very appreciative if someone listed the bolt sizes.
  4. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    add me to the list. this hurricane is dumpin some rain here
    nathan
  5. JoshA
    JoshA 1/2 ton status
    Apr 9, 2001
    104
    slc,ut
    all of the bolts for the hard top (double wall, not sure if there is a difference for single wall)
    are 5/16". the bolts for the bed rails are 2" long, and the 2 center windsheild frame bolts are 1" long (maybe 1 1/2").
    the bolts that go through the visor hangers are closer to 3" long but I'm not sure about their exact length.
  6. tp85
    Mar 14, 2002
    130
    Maryland
    My two center windshield bolt holes appear to be only *holes*. Are they supposed to have a threaded nut on the inside of the hole (inside the windshield frame)?
  7. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    I'm sure you have the nuts in the windshield frame, just not where you want them. You might find them by the window side post. So how do you put a screw into it? I'm at work and truck is home so I can't look to see how I did it, but I think I drilled a hole on each side of the missing nut and taped it. Then I drilled 2 new holes to match in the top bracket, If you need more info or pics let me know.
