Doubler 208 ????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by White Knight, Mar 18, 2002.
  1. White Knight
    White Knight 1/2 ton status
    889
    Ft Worth,Texas
    Toying with a Idea, see link to pix http://coloradok5.com/gallery/albuo05/aaw
    doubling a 208, besides the lengthing and shortening of the drive lines, possibly a carrier at the front drive shaft, additional adapter, shifter linkage for additional t-case and cross member to support second t-case, taking chain out of first t-case (no need to turn front output flange.) and anyone see any other problems with this Idea. The t-cases are mated in the picture output to Input, and what crawl ratio would I expect to have?? I'm really considering this improvement this summer, hence the request for info????? Has anyone out there attempted this?, I know about the 203/205 doubler, but have never heard of a 208/208.
    White Knight (orginal and Texan)
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    There is a post right now in the ORD Forum about using a doubler with a NP241, and in Stephen's reply he said you can use a 208 in a doubler combo. I don't know about a 208/208 doubler though.
  3. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    hey white knight if you find out some info let me know...im definitely interested in this improvement...
    i wonder could you mate a chevy 208 as the front t-case and a dodge 208 as the back so you could have a fixed yoke in the rear?
    might be something to think about...
    Later
  4. White Knight
    889
    Ft Worth,Texas
    I posted on Ord thing also, and If I find anything out I'll post here.
    White Knight
  5. BADASSBLAZE
    BADASSBLAZE Registered Member
    Jul 20, 2001
    63
    Pollock Pines, California
    It looks to me that it will be too long. I'd rather go with a tried and true method, the ORD 203/205 Doubler.
  6. White Knight
    889
    Ft Worth,Texas
    Yeah I'm aware of the length issues, front shaft will have to lengthen and have a carrier, positioned somewhere close to the leading t-case, rear drive will shorten approx. 21", have to go to a high angle drive line with cv's. But in all of this I convinced of having a outrageous ratio with the 208's having a orginal 2:61. Grimmy any input?
  7. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Im no expert, but wouldn't that be a lot of torque for those transfer cases? Definately would be a far cry from bullet proof. But maybe Im wrong about this.
  8. XtrmChevy
    XtrmChevy 1/2 ton status
    Jul 14, 2001
    148
    Finland, Europe
    "I did it my way..." rotated the 208 out of the way of the front shaft and then a divorced 205 behind it. The combination IS long but with a long bed I think I can get away with it. The rear shaft will be about 35" long. And a carrier bolted to the raised crossmember of the 208 (4 u-joints and 2 slipyokes in the front shaft...). Maybe need a CV out back but if I angle down the 205 I do not .
  9. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    *mischevious grin *
  10. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    If you keep your foot out of it when the front case is in low range, it sounds like a cool idea. But if you like to stomp on the happy pedal a lot, then it's probably a great way to make lots of itsy-bitsy 208 bits. /forums/images/icons/wink.gif
