doubler combination questions
Discussion in 'The Garage' started by short sub, Jun 2, 2005.
  1. short sub
    short sub Registered Member
    Jan 17, 2005
    98
    Sealy Texas
    i have an ord doubler- triple sticked- 32 spline yada yada, and i have heard that it isnt recommended to run the 203 in low and the 205 in high. Is this true? and if so why? i like that range. thanks Ryan
  2. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    I saw a post by Watson (in the ORD forum) that said this scenerio could break their shaft.
  3. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    It is uaually wise to use your reduction as far down the line as possible so that the reduction , or torque multiplication is at a minimum at certain points. Running a range box in low and a 205 in high range puts more stress on the input shaft of the transfercase but when the transfercase is in low range it makes life easier on the input gear/shaft because of the help from less resistance from the gear reduction of the case.
    I don't think they ( ORD ) are worried about a weak link , it is just wise to use your reduction as far down the line as possible when ever possible to avoid over powering certain parts when it is not needed.
    I hope this makes sense - Tom
