Doubler Crossmember pics
Discussion in 'The Garage' started by JpEater, Feb 26, 2006.
  1. JpEater
    JpEater 1/2 ton status
    Nov 20, 2005
    299
    Augusta, Georgia
    What does everyone think about this crossmember? It is 1.5" x 1.5" x 3/16 tubing and the frame mounts are 3 x 3 x 1/4" angle. The t-case mounts are 3/8" plate and I used 1" thick pucks. I think it will be plenty strong but I would like to know what you think about it before I take it out on a ride. I still have to put some more bolts in the frame and make the skid plate after the triple stick is in.
  2. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    very nice!!!
  3. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    Looks real good. What truck is it bolted up in?
  4. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    looks like it hangs down quite a bit... otherwise very nice. :thumb:
    j
  5. JpEater
    Nov 20, 2005
    299
    Augusta, Georgia
    The truck is an 86 1 ton/K10 with 6" and 37's. The case is rotated up 2" and I made the crossmember almost as high as I could get it. I left about 1/2" difference from the bottom of the case to the bottom of the crossmember for any compression of the mounts. It is a big improvement over the stock. When the skid plate is completed it will flow good when I drag a rock.
  6. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    solid mounted to the frame? No bushings? How is your engine mounted? I've read on here that you should match mount them, so either both solid, or both with bushings, so theres no flex between the 2
  7. JpEater
    Nov 20, 2005
    299
    Augusta, Georgia
    I have the polyurethane ORD motor mounts and 1" thick polyurethane pucks mounting the doubler.
