Doubler Crossmember
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TheGeneral, Jan 17, 2002.
  1. TheGeneral
    TheGeneral 1/2 ton status
    Feb 22, 2001
    556
    NC, USA
    Doubler is in and now new shafts. Question is, how high should I mount the crossmember. I have only mounted the rear one (welded in some 1.5 X 4 1/4" thick tubing to extend crossmember for this) Question is, I used to have my 241 lowered, should I do this now also or mount the crossmember up to frame. I have the dual CV's front rear and angles are good, but main question is that I forgot the original angle of engine/trans. If I remember correctly it sloped down a little as it went to rear. My trans pan is level as it sits now (1" spacers in between frame and crossmember), so am I hurting anything to get rid of the 1" spacers. I have the clearance between the fan and raditor and lower crank pulley and engine crossmember, but now the trans pan would be 2 degrees sloping towards front. Obviously, I would like to mount the crossmember up tight as possible, but don't want mess anything up. Any advice would be appreciated.
    If you ain't hurt, you ain't playin' hard enough.
    The General
  2. Greenblazer-AZ
    Greenblazer-AZ 1/2 ton status
    Jan 4, 2002
    770
    Chandler, AZ
    Hey General, I don't know but you might try posing this on the ORD forum. You might even get help from Steve on this.
    If you knew the truth, you too would be against marijuana prohibition!
    Blue '74 K5 Blazer Topless W/ 35 BFG Muds (See profile for pics)
  3. TheGeneral
    Feb 22, 2001
    556
    NC, USA
    Yea, I did that too, but a lot of members read the main board more and have the knowledge as well. Thanks.
    The General
  4. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    If you can mount it up to the frame and the shaft angle is correct and no vibs driving down the road you should be fine. So are you going to bring that beast up to wheel with us at Paragon in August?
    See <a target="_blank" href=http://coloradok5.com/gallery/Waynes-Toy>Project Mighty Mouse</a> here.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  5. TheGeneral
    Feb 22, 2001
    556
    NC, USA
    Sounds like a good idea. I should be ready, still have to get bumpers, winch, and some other stuff. What are the dates? I will be in new command then so I should be able to make it.
    The General
  6. mnstr_fx
    mnstr_fx Registered Member
    Sep 13, 2001
    78
    IL
    I mounted my doubler using both the front and rear cross members. I started by setting the transfrer case / transmission height with the front cross member. This maintains the stock angle for the drive train. Then I used some 1/2 - 3/4" spacers to install the rear cross member.
    Both cross members are stock GM stuff just drilled / slotted to fit the frame.
    76-82 Chevy Pickup / Blazer - K5-K10-K30
    90' TBI
    TH 400
    203 / 205 Doubler
    Dana 60, Corp 14 - 4.88'd - Detroit Locked
  7. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    As of now it is being set up for Aug. 10th and 11th. By the looks of it this might turn into a fairly big event.[​IMG]
