doubler/driveshafts
Discussion in 'OffRoad Design' started by elacruze, Feb 3, 2004.
  1. elacruze
    elacruze 1/2 ton status
    Dec 23, 2003
    121
    SE Michigan
    My truck has a TH400/205 now (round pattern, slip yoke). I have a TH400/203 combo on the shelf. First, are all TH400 cases created equal (viz. K case 350)? Second, if I install the 400/203 in the truck, can I have shafts built around that and be assured that they'll be the correct length for the doubled 205 (with short input, fixed yoke)? How much is front length affected by the 2" rotation? I'd like to have as little downtime as possible; I could have the shafts built at the same time as the tranny work and doubler install.
    Am I forgetting anything?
    Eric
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Congrats on having perfect parts.
    You can count on the rear driveshaft length being the same as the 203 but the front shaft with the Doubler will have to be 3" longer than the front shaft for the 203 by itself.
    Remember, you will need the short 32 spline input gear in that round pattern NP205 if that's the one you want to use for the Doubler.
    On the transmission case, I'm not an expert in this area, and I know the 4wd cases are more desirable, but I don't know if there's any difference between early and later models. You can probably just take your pick between the 2.
  3. elacruze
    Dec 23, 2003
    121
    SE Michigan
    To be clear; with doubler, short input shaft in 205, fixed 205 output, and clocked 2" up..
    Rear DS length is equal to th400/203 stock.
    Front DS length is +3" from th400/203 stock.
    Are the 205 and 203 front flanges the same pattern for the DS?
    Eric
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    You got it right. I'd wait till it's done to measure for the front, but the rear should be OK to do mocked up with just the 203 in there.
    The 203 and 205 flanges are the same part, they interchange directly. So yes, they are the same pattern. The thing you'll have to watch on the front is the rotation, along with the 3" back, you'll go about 2" up and that could mess with the length a little bit.
  5. elacruze
    Dec 23, 2003
    121
    SE Michigan
    I didn't consider driving the truck with only the rear. Duh.
    OK then, I'll be ordering the doubler, 205 input shaft, and triple stick shifter as soon as the butter and eggs are sold.
    Eric
  6. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    As much as I like butter and eggs, I can't eat enough to offer you a trade, so I guess we'll wait a little.
