doubler help, PLEASE
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by four_by_ken, Apr 25, 2002.
  1. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    Ok, may have a line on a 400 205 t-case. But, I need to know if it is the right one for use in a doubler set up. As I understand there is a long and a short.
    Does nayone know what years the "good" short one came in? Or does the year not matter?
    Ken H.
  2. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    There is a good link off of ORD's website that lists this, but if I remember correctly, the short 32 spline female was changed to the long about '85. So anything before 85 should be ok. Stay away from '84's, because they (like mine) have a slip yoke rear, which isn't the ideal setup for a trail rig.
  3. four_by_ken
    Jun 9, 2001
    3,806
    Allenton, MI
    I can get a 205 from a 400, but it has the slip yoke.. that can be converted over to a fixed, right?
    I have a 205 that is a fixed yoke. Cant I just swap them?
    Ken H.
  4. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    it should be a simple swap slip to fixed yoke
  5. mnstr_fx
    mnstr_fx Registered Member
    Sep 13, 2001
    78
    IL
    Ken,
    80' and newer were all slip yoke. 79' and older were fixed yoke. Converting from slip to fixed is cake. All you need to do is swap the rear nuget, (i.e. everything from the rear bolt pattern of the output carrier onto the main case of the 205) Find an old SM465 manual 205 or some other 205 and switch everything. The other difference is between the small bearing and big bearing on the input to the 205. You need the larger input bearing and female input shaft. This would also be an 80' or newer item.
