Doubler in a DD, anybody have problems with the 203 slipping out of HI?
Discussion in 'The Garage' started by FWP, Dec 8, 2002.
  1. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Just curious if anyone has the same problem. I know therobzilla does, and from a search, BILLYRAY also. Marv Springer's doesn't, and I haven't figured out why yet. Any suggestions or solutions would be cool. The bungee cord thing needs a permanent fix.....
  2. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    one thing i do know (or think i know) is Marv has a gen I doubler--are the ones having problems all in gen II's
  3. therobzilla
    therobzilla 1/2 ton status
    May 15, 2001
    1,307
    Gilbert, AZ
    Fred,
    As you know, I too have this problem, the 203/HI range shifter slipping out of gear.
    I can't believe no one else has had this problem using the Gen II doubler.
    Anyone???
    Therobzilla
  4. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Yeah, I got a problem w/ my doubler....
    When I'm flyin' down the interstate, it slips into triple-high-and-a-half, and I get goin' so fast that the hood blows off! /forums/images/graemlins/tongue.gif
    Just tell Josh to quit kickin' the levers /forums/images/graemlins/rotfl.gif
    Marv
  5. Grim-Reaper
    7,385
    Atlanta
    Are you using the stock shifter for the 203?
    Stock shfter on the unmolested 203 has a detent mechanisim in it that prevents it from coming out of the gear it was put in by any other way than the lever being moved. Does that shifters your now using do that?
  6. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    No, the stock 203 shifter is not used, generally, for the doubler setup. I have a post on the ORD board from a week or so ago, bringing the detent thing up. The single range case shift needs to be designed to hold it in place. The original 203 shifter handles that problem, but I am trying to find out if anyone has come up with a solution for the shift out of gear, without a detent in the shifter mech. I have a few ideas, but before I try to re-invent the wheel /forums/images/graemlins/wink.gif..........
