doubler in, have a couple questions.
Discussion in 'OffRoad Design' started by leadfoot067, Mar 27, 2002.
  1. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    ok got the doubler in.its a gen 1.put it in a 73 blazer.1st i ended up with a rear driveline length of 30".lowered rear crossmember about an inch for floor clearance.but should also help rear driveline angles.should i do a one inch body lift and lose the spacers?also can i get just the double shifter boot?if so how much?
    thanks
    shane
  2. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    remedy all your problems and give it to me...
    /forums/images/icons/smile.gif
    grant
  3. leadfoot067
    May 14, 2001
    1,563
    ya ill give to ya,trade ya for a complete gen2 doubler with a 465 in front please.lol
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Dropping the case is always a trade off of angle vs. ground clearance. If you want the clearance and can sacrifice the angle, pick it up, otherwise leave it down for a happier driveshaft.
    We do sell the boot separately, usually with the hold down rings. It'll run you about $40 for the whole assembly.
