Doubler install help please
Discussion in 'The Garage' started by SCOOBYDANNN, Dec 13, 2003.
  1. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    I posted this in the ORD section too, but didn't know if Steve would be on this weekend.
    What is the best way to get the shift fork out when it's the type that dosn't come out on purpose.
    thanks
  2. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Huh? Are you talking about the range box? I'm afraid I'm not following you... but it's late and I'm exhausted... maybe in the moring. /forums/images/graemlins/laugh.gif
    G-night all! /forums/images/graemlins/rotfl.gif
  3. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    Remove the pin from the shift fork and booya it comes out! /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
  4. SCOOBYDANNN
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    sorry---bad choice of words---i mean the shift rod---the one that comes out of the 203 or the range box.
  5. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    I'll give this a shot /forums/images/graemlins/tongue.gif
    Remove the nut that holds the external shift linkage,remove linkage, then there is a snap ring holding the next link in place. Remove that, then remove that linkage. Now you should be able to push the shaft into the case, it doesn't take alot. That should allow you to remove the internal link. Then push the shaft back out in to position. Sure hope that is the one you are talking about /forums/images/graemlins/thinking.gif /forums/images/graemlins/rotfl.gif
  6. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    If your talking about the rod from the range box to the chain box, just crack the case ¼ or so and cut it. That’s what I did.
    Or are you talking about the rod twisted by the external linkage to work the internal rods, the one with the little linkage brackets on the outside of the range box? If so, that doesn't need to come off. Just leave the unneeded portion in there, it's the easiest way and hurts nothing...
